Mighty Stripes
Old May 14th, 2006, 04:38 PM   #1
bemini
Be MiNi
bemini's Avatar
Local Time: 06:14 AM
Send a message via MSN to bemini
DIY starting spraying but come across a problem
i have rubbed down the dash and primed but when i sprayed the first coat of paint it reacted, would this mean there was some old laker on the dash or somik else?
I HAVE THE MINI FEVER !!!
Old May 14th, 2006, 05:11 PM   #2 (permalink)
faster,Tobias!
Fanatically Enthiusiastic
faster,Tobias!'s Avatar
Local Time: 11:14 PM
bemini,
Do you mean lacquer?
Is the paint you are using the right stuff for plastic, or whatever it is the dash is made of? I'm no expert, but paints are different dependant on the application. Paints for metal may not stick to plastics. If it is a suitable paint then I would guess the paint is sliding of the dash finish, and needs more rubbing down. Good luck with it.
Old May 14th, 2006, 05:59 PM   #3 (permalink)
Jim Ray
AprilWhine's Fuzzy One
Jim Ray's Avatar
Local Time: 09:14 PM
Is the primer you used the same brand as the paint, and recommended for use with the type paint you are spraying?
Remember, the first coat of paint should be thin enough to see through.
Let us know how it goes.
Old May 14th, 2006, 06:06 PM   #4 (permalink)
fireman01
60mpg
fireman01's Avatar
Post
was there any dashboard cleaner on it? this causes a reaction if you don't get it all off,the dash is already painted shouldn't need a primer.iv colour coded mirrors for people before and found plastic dressings like back to black etc cause this.let the paint dry rub down again(being careful not to go to far through or you will need primer)then clean with pre paint(panel wipe)and start again.
Old May 15th, 2006, 11:06 AM   #5 (permalink)
bemini
Be MiNi
bemini's Avatar
im going to rub down it totally again and then see the results and let you know
Old May 15th, 2006, 02:59 PM   #6 (permalink)
weemark
sounds like the panels need cleaned with thinners or panel. a lot of polishes have silicon in them which will react with paint - you need to make sure there is no silicon about at all. think id strip them completely and clean with thinners. also make sure your primer/paint/laquer is all the same type i.e. 2pack or otherwise.
Starting problem rabbit Faults & Fixes 0 Mar 16th, 2007 07:50 PM
Starting Problem Weeble 2nd Gen Faults & Fixes 1 Jan 20th, 2007 11:22 PM
Starting problem????? duke748 Faults & Fixes 0 Jan 20th, 2007 07:30 AM
New starting diesel problem! Kissato MINI One Diesel 23 Feb 22nd, 2005 02:57 PM
strange starting problem... DarkMiniCooperS Faults & Fixes 2 May 17th, 2004 08:58 PM
