Visit Out Motoring!
Old Jul 26th, 2002, 02:20 PM   #1
zogbogbean
Local Time: 09:49 PM
Send a message via AIM to zogbogbean Send a message via Yahoo to zogbogbean
Remote Lead on Stock Stereo for Amp?
I would like to put a rockford amp and sub in my MCS using the factory head until I decide what to replace it with.
Does anyone know if there is a remote lead coming out of the factory head (REM, usually a blue line out of a aftermarket din) that I can splice into so the amp will turn on? Or does someone know a trick where I can pick up a power source the right size, add a switch to it and wire it in that way?
Thanks,
Greg
Old Jul 27th, 2002, 07:07 AM   #2 (permalink)
Dom
Test thread infiltrator
Dom's Avatar
Local Time: 10:49 PM
Send a message via MSN to Dom
Re: Remote Lead on Stock Stereo for Amp?
Thanks,
Greg
There isn't one. However, now this I've got a hangover so bear with me... Try and find something in the fuse box that doesn't draw much power and only comes on with the ignition - could you splice it from there? I haven't looked but it seems like a solution to me - anything my poor tired little mind has missed?
Dom
England View Dom's British Racing Green & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 30th, 2002, 04:46 PM   #3 (permalink)
GaryM
GaryM's Avatar
Send a message via Skype™ to GaryM
Oh yes there is.... It is the White wire comming out of pin 13 of the large connector in the multiway connector shell. Find the fuse then work up the pins above to the top right and there it is. Splice in to this.
It goes live to power the antenna amp. I use it as the remote for my RF 500x!
Old Jul 30th, 2002, 04:47 PM   #4 (permalink)
GaryM
GaryM's Avatar
Sorry missed the obvoius here, the large connector on the back of the head unit.
Old Jul 30th, 2002, 04:52 PM   #5 (permalink)
zogbogbean
THANKS!
Perfect! That is much better than mucking around in the fuse box!
Thanks again,
Greg
Old Jul 31st, 2002, 09:41 AM   #6 (permalink)
Dom
Dom's Avatar
I stand corrected! I blame the hangover... made me think TOO laterally
Thanks Gary,
Dom
Old Aug 1st, 2002, 06:42 PM   #7 (permalink)
Genxslkr
Local Time: 02:49 PM
Pin 13-white is the power-antenna. You might also try pin 16-purple/blue that is the accessory I think (not sure) that is the same as a REM line.
This is from thread.
http://www.mini2.com/forum/showthrea...&threadid=9744
MCS Chili Red w/white roof, Premium and Sport
Old Aug 3rd, 2002, 05:56 AM   #8 (permalink)
GaryM
GaryM's Avatar
Correct pin 13 is the accessory wire but this is used to signal the HU to power up when the ignition is on. If used for the remote of a amp it would mean that the amp is on all the time the ignition is on! This in turn may well mean that you get horrible pop's as you switch the HU on and off.
stock stereo plays possum cristo Interior & Ice 9 Apr 20th, 2008 06:25 PM
Best bang for buck stock stereo mods Tonefiend Interior & Ice 13 Mar 29th, 2006 06:17 PM
Audiophiles: Stock Stereo Complete Trash? GMINI Interior & Ice 51 Oct 29th, 2002 03:22 PM
