| Tags: bluetooth, mfsw, newministuff, parrot, plug play |
| | #21 |
| MINI2 Newbie Join Date: Dec 2006 Local Time: 10:51 AM
Offline | @DaFlake It's pretty new, November 2006 (old version)! |
| | #22 (permalink) |
| Lovin' every MINI of it! | If you are trying to remove the HU, you can simply angle the down tubes out to get to the bolts. However, if you need to remove the center portion of the console, you have four screws holding it down. Two located in each cup holder and two that are located under the little panel that has the switch for the mirrors and heated seats. The easiest way to get that switch box up to get to the screws is to pull up the gear shift boot. Once you get the screws out, then you can slide the center console back and it will come loose. Global Moderator ![]() Last edited by DaFlake : Jan 2nd, 2007 at 08:43 AM. |
http://www.mini2.com/forum/ | |
| | #23 (permalink) |
| I can't get no sleep Join Date: May 2002 Location: Capital of Culture Local Time: 10:51 AM
Online | On the 06 there is no need to touch the centre console, Pull down the drivers knee bolster (they can be very tight) get you hands in between the boster & column covers & pull down it is held by to clips at the top & is hinged at the bottom. You can then get to the top pillar screw. Remove all 4 pillar screws as shown earlier, the pillars will drop & you can push them outwards to remove the radio screws Flakey you have a pm |
| | #25 (permalink) |
| Crapping in the woods... Join Date: Jun 2005 Location: Sydney Local Time: 08:51 PM
Offline | Mikey, Got a question on this. Got the relay for the MFSW and install would be similar to this (I think). Where the heck does the unit attach to the MFSW bluetooth button?!? I've got the Speech button relay interface (BMW01REL) Cheers. ![]() |
| NEW Bluetooth kit for Minis with phone buttons on MFSW - plug & play - EVO | mikeythemini | Interior & Ice | 17 | Apr 14th, 2007 06:24 PM |
| Bluetooth kit iwith screen in R56 without MFSW (Parrot 3200) | mikeythemini | 2nd Gen Interior & Ice | 0 | Apr 4th, 2007 09:11 PM |
| Bluetooth kits for R56 Mini - retro fit, works with MFSW from £160 | mikeythemini | 2nd Gen Interior & Ice | 20 | Mar 14th, 2007 11:01 PM |
| Retro fit Bluetooth kits for new MFSW Minis | mikeythemini | Interior & Ice | 51 | Feb 13th, 2007 08:55 PM |
| Thumb switches CVT transmission retro-fit kit for MFSW | ar75 | CVT & Automatic | 14 | Dec 1st, 2002 10:31 PM |
