Wipac
Old Dec 2nd, 2006, 02:08 PM   #1
peab1
Local Time: 12:07 AM
Sat Nav Retro Fit
Hi,
Can someone please tell me how to retro fit a factor sat nav into my 2002 Mini Copper?
I know it's tricky but it can be done.
Are there any extra parts I need?
Old Dec 2nd, 2006, 02:26 PM   #2 (permalink)
AprilWhine
Loves the Fuzzy One
AprilWhine's Avatar
Local Time: 04:07 PM
Send a message via AIM to AprilWhine Send a message via MSN to AprilWhine Send a message via Skype™ to AprilWhine
Check this thread: http://www.mini2.com/forum/interior-...retro-fit.html
Global Moderator
United States Visit my Blog at the Motorcade Female   Reply With Quote
Old Dec 2nd, 2006, 02:54 PM   #3 (permalink)
peab1
HI AW,
Thanks for your post. I've already checked that thread, and someone mentioned they'd done it but it was a big job.
Does anyone else have any more info on this?
Old Dec 2nd, 2006, 03:43 PM   #4 (permalink)
S33BBY
Don't bother, it's too big a job and too expensive. I appreciate that you probably want a built-in solution, but it's just not feasible.
Speak to Mike from NewMINIStuff.com and get yourself one of those head units with a pop-up screen.
JCW Sound Kit | H/K | Sat Nav | SS+ | Xenons | 17" Anthracite R90s | Goodyear Eagle F1 GS-D3s | ...
United Kingdom Male View S33BBY's Hyper Blue & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Dec 2nd, 2006, 04:21 PM   #5 (permalink)
AprilWhine
Loves the Fuzzy One
AprilWhine's Avatar
S33BBY is right, my hubby is almost finished installing a Pioneer AVIC-N3 in my GP. Better function and cheaper too. I'll be posting pictures and a write up DIY soon.
Global Moderator
Old Dec 2nd, 2006, 05:13 PM   #6 (permalink)
peab1
Thanks for the replies!
S33BBY - Out of interest is the great expense buying all the kit?
And secondly what makes it a big job? Perhaps I am being a little naive.
I realise the Sat nav needs to be connected to electronics and stereo system. And installing the fin antenna and running the cables. Then reconnecting the smaller speedo over the steering column.
Would be interested to hear if anyone has done it.
AW - Look forward to seeing the write up.
Old Dec 2nd, 2006, 05:17 PM   #7 (permalink)
S33BBY
I'm not sure off hand, but it's sure to run into the thousands!
Do you not think this is a big job?
The taking the car apart is a big enough job in itself, plus fitting everything, and the time to resolve potential for problems. It's just not worth the hassle unless you specifically want to undertake it as a project.
Old Dec 2nd, 2006, 06:54 PM   #8 (permalink)
mikeythemini
I can't get no sleep
mikeythemini's Avatar
Did you find the wire??
Old Dec 2nd, 2006, 08:59 PM   #9 (permalink)
AprilWhine
Loves the Fuzzy One
AprilWhine's Avatar
He found a blue w/yellow trace on the left sill and hooked it up, but the unit says no speed pulse. I hope it's just a learning curve, the unit didn't recognize the handbrake signal at first either.
Mikey, he wouldn't have kept looking if not for your advice, THANKS! He also says sill trim installer at the factory must be the equivalent of purgatory.
But so far, everything is working well. Just have to finish tidying up for pictures then I can post the whole illustrated story.
Global Moderator
Old Dec 2nd, 2006, 09:20 PM   #10 (permalink)
Jim Ray
AprilWhine's Fuzzy One
Jim Ray's Avatar
Local Time: 03:07 PM
And she has to clean the blood from the sill trim.
Tomorrow to use a thousand wire ties and neaten up everything. I am saving the MFSW connection for a day when the skin on the back of my hands has healed.
Mikey, you earn every penny on one of these installs. I read every post you have made about ICE installs, and I would have never tackled it without your posts to refer to.
I have spent years working with electronics, computers, etc. Doing the install in not tough, I can do it in ten minutes on a sheet of plywood. Doing it in the car took a two days last weekend, evenings for a week, and most of two days this weekend. A spare car to drive is a must.
A second install would take a lot less time.
Power the car up with the seats removed, and then you have a trip to your friendly dealer.
Old Dec 2nd, 2006, 11:24 PM   #11 (permalink)
peab1
Hi guys,
Thanks for all your helpful replies. Looks like the Pioneer might be the sensible option but I'm still interested in checking out the retro fit.
Looking forward to reading the Pioneer install.
Old Dec 3rd, 2006, 11:19 AM   #12 (permalink)
DaFlake
Lovin' every MINI of it!
DaFlake's Avatar
Local Time: 07:07 PM
Online
Definetly a huge amount of man hours to install and the unit alone is very expensive. The Pioneer solution is a cheaper and better solution.
Global Moderator
United States http://www.mini2.com/forum/Visit my Blog at the Motorcade Male View DaFlake's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 3rd, 2006, 04:04 PM   #13 (permalink)
peab1
I may seem a bit crazy but if I can get hold of the parts cheaply then I'd quite like to do it as a project over the Xmas holidays.
Would really like to know of the complications I may have.
Realise I need to get a shark fin dual gps and fm antenna which will need to be threaded round to the front console, and that once everything's connected up I'll need to get it coded at a dealer.
Does anyone know of any complications I may have?
Old Dec 3rd, 2006, 04:09 PM   #14 (permalink)
DaFlake
DaFlake's Avatar
Online
There is more to this NAV than just a system. There are wheel sensors, gyros and such that have to be fitted along with the the unit, wiring harness and display. Basically, you are not stuffing a Tom Tom into the dash. This is a system that knows which direction you are facing at a standstill and can continue to track you even with a loss of signal. Most of the people that have actually done this swore they would never do it again.
That being said, if you like a challange, go for it.
The other problem is that this system could cost you well into 2 - 3 K (dollars) easily and you can get a much better after market for this amount.
Global Moderator
Old Dec 3rd, 2006, 04:22 PM   #15 (permalink)
peab1
I knew about all the harness cabling etc,. but didn't realise about the wheel sensors and gyro.
Getting hold of those isn't going to be easy.
Old Dec 3rd, 2006, 04:34 PM   #16 (permalink)
James
James's Avatar
It would probably be easier to make your own satnav system by integrating an aftermarket one behind the screen. It might not have the same display but it will save a lot of money and time.
retro sat nav b21playa Interior & Ice 6 May 9th, 2007 05:19 PM
Retro fit sat nav Russell Interior & Ice 17 May 7th, 2007 07:28 AM
Can I retro fit tv/sat nav screen paulswoop Interior & Ice 6 Oct 16th, 2005 12:02 PM
MINI Sat nav-Retro Fit? ALD0 Interior & Ice 5 Nov 15th, 2003 03:41 PM
Retro fit BWM Sat-Nav dabe Interior & Ice 2 Jul 16th, 2003 03:17 PM
