| Tags: map, nav, sat, upgrade, version |
| MINI2 Newbie | Sat nav version and map upgrades I need someones help please! After reading some info on the X5 site and here, I am very keen to upgrade my sat nav to V28 and get the newer maps, preferably with the speed camera POI's. I am, however, relatively computer illiterate! Is there someone who can supply me with the discs I need ready to go or provide me with an idiots guide? I have the DVD sat nav (4th gen) in my 2003 cooper S. Thanks. ![]() |
| Dog Tired | Welcome to the forum... Do you know how to burn cd's? As far as getting maps, you will have to purchase those as they are not free. Also, adding camera POI's requires that you purchase the camera database and reburn the disk. Not an easy task, but not impossible either. Do you have a DVD burner? Software updates for the NAV can be obtained and you can actually use the link from x5world to get it, Once you have that I can help walk you through the burning process. Lastly, what burning software do you have? This will help me help you in the future. I personally use NERO for pretty much everything. Good solid application. Global Moderator ![]() |
| Scribbler Join Date: May 2005 Local Time: 01:42 AM
Offline | I just went and downloaded the v28 upgrade from the link on the X5world.com site. I downloaded the .ISO image to my Mac, burned it to a CD using Disk Utility, and installed it without difficulty. It gets a lot more information out of my 2006 DVD than the older version did, and I love the perspective view. Paul |
| | #7 (permalink) |
| MINI2 Newbie Join Date: Jan 2007 Local Time: 09:42 AM
Offline | Hi, With regard to burning this to CD/DVD does it have to be an "image" or just a straight forward data disc? I'm not running nero but a pre-installed "power to go" program which won't allow me to burn an image. Any thoughts much appreciated. P.s great site - loads of interesting info. |
| | #9 (permalink) |
Offline | Hi DaFlake, Thanks very much for that. You don't need me to trouble you with my computer problems but I'm a little confused. I've burned from an image before without problems. However, V28 as it stands is saved in My Documents and when i open the burning software I cannot see V28 or browse for it. Apparently the burner is looking for a specific type of file: Image Files p2i; iso. The V28 is a .RAR file. Is this my problem? Or - either i'm being stupid or my software is not geared for this. I'd appreciate your advice. Regards dan |
| | #10 (permalink) |
| Dog Tired | LOL, you are not being stupid. RAR is a compression utility like ZIP. the Image is actually in the RAR. So, you will need to extract it from the file. If you google RAR, you will get the RAR site WinRAR archiver, a powerful tool to process RAR and ZIP files This site costs money but there is a trial. There is a better utility that is free and can handle many different types of compression utilities. It is called Tugzip TUGZip - The Free Archiving Utility This tool will allow you to open the RAR files and extract what is in them. Once you get it extracted, you can then burn it to a CD. I use Tugzip at home and work. Just be sure to check the boxes to activate RAR support during the install as it is optional. After that, you can use Tugzip for just about all of your archive utilities. Global Moderator ![]() |
| | #12 (permalink) |
Offline | Hi again DaFlake, I followed your advice and downladed TUGZIP. I managed to run the V28 (RAR file) through it and it has generated two files: V28.mdf (25,431Kb) V28.mds(1Kb) I trust that both of these must be burned to the DVD using the image burn process - is this correct? Thanks Dan |
| | #13 (permalink) |
| May the Mini be with you! Join Date: Feb 2005 Local Time: 10:42 AM
Offline | Download a trial of Alcohol 120% (do a google for this), install and use burn image to disk option. Look for the .mds file for the v28 and select this. Then you can burn the disc. FYI the MDF file holds the image of the disc and the MDS file is used by Alcohol 120% to access the MDF file. |
| | #15 (permalink) |
Offline | Jonesy, DaFlake, Thanks for your advice/patience. Unfortunately, I seem unable to complete this simple task! I've done the following: Downloaded the V28.RAR file Downloaded and used Tugzip to handle the file Downloaded and installed Alcohol 120% I use the image burning option within Alcohol 120% and it initially finds the file in my docs right away. I insert the DVD into the drive and it detects that ok. However, when I press start it asks me "insert a disc into the drive". I've ejected/re-inserted and it still doesn't like it. I've tried both DVD-R and DVD-RW - but still no success. I've tried different discs and even combinations of firewall on and off. I've looked in the help section of alcohol for drive related errors or problems but they don't have a section for that. And finally - to add insult to injury - their web based help forum won't allow me to register. i checked to see if the drive is supported and it appears as though it is and besides it seems to detect and name the drive properly during startup. Two, very final questions for you guy's before I give this up as a bad job: 1, Is there any other obvious reason why Alcohol won't proceed when the media is already in the drive? 2, Failing this, is there another program for burning this file to disc? Many thanks, Desperate Dan |
| | #19 (permalink) |
| MINI2 Newbie | I know this is an old thread but this is what I did to burn the CD: 1. Down the the RAR file from x5world 2. unrar it (winrar on windows or Stuffit on a Mac) 3. rename the V28.mdf V28.iso 4. Use Nero on Windows or Toast or Disk Utilty on a Mac to burn it to a CD Stuck it in the nav drive and although it failed on the first attempt, on the second it worked. ---- Mike Butler 2003 MCS Dark Silver |
| Sat Nav Version | KRIZT | Interior & Ice | 37 | Jul 16th, 2004 09:07 PM |
| Sat Nav Map CD's | ALD0 | Interior & Ice | 15 | Jun 1st, 2004 02:45 PM |
| eu Map Disk - Sat Nav | ashley adam | Interior & Ice | 0 | Sep 22nd, 2003 02:15 AM |
| Sat Nav Software Version Number | clallo | Interior & Ice | 3 | Aug 26th, 2002 02:19 PM |
| Mini Sat Nav - Map Swap | woodman438 | Interior & Ice | 3 | Aug 23rd, 2002 12:13 PM |
