Mighty Stripes
Old Jan 13th, 2007, 01:11 PM   #1
fozworth
Local Time: 12:44 AM
What is the red light for on the end of my replacement indicator stalk??
I have just bought a new indicator stalk with a computor button so i can retro fit the computor option but the new stalk has a red light on the end the same as my wiper stalk which shows the Alarm is activated .So what is the red light on the indicator side for ?and will it matter if its not used.or can it also be used for something else
Old Jan 13th, 2007, 01:33 PM   #2 (permalink)
Random
On a Hellride
Random's Avatar
Local Time: 06:44 PM
That light indicates whether the alarm system is armed.
United States Male View Random's Astro Black & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 13th, 2007, 01:44 PM   #3 (permalink)
DaFlake
I miss my MINI
DaFlake's Avatar
Local Time: 07:44 PM
Yep, you have an alarm stalk. However, you can use it as you would the normal one.
Global Moderator
Old Jan 13th, 2007, 03:14 PM   #4 (permalink)
MartinSSZ
Yellow and Proud
MartinSSZ's Avatar
Send a message via MSN to MartinSSZ Send a message via Skype™ to MartinSSZ
You've got an stalk which would usually be fitted to alarm-equipped post January 2005 cars, when MINI introduced the low washer fluid warning light on the right hand stalk.
The alarm LED swapped stalks at that stage, so you'll now have 2 - except that the "new" one won't work unless you wire it up
United Kingdom Male View MartinSSZ's Liquid Yellow & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 13th, 2007, 03:24 PM   #5 (permalink)
fozworth
indicator stalk
Hi thanks for that so if my stalk on the wiper side already has a factory alarm light does this one just not work .basicaly i bought it for the computor switch so i can retro fit one so i can still do that cant i?I guess a red light both sides will look quite cool anyway.
Old Jan 13th, 2007, 03:35 PM   #6 (permalink)
MartinSSZ
Yellow and Proud
MartinSSZ's Avatar
Should work absolutely fine, I can't imagine that they'd have changed the connector or pin layout between stalk types
Old Jan 13th, 2007, 05:50 PM   #7 (permalink)
rkw
Local Time: 04:44 PM
Here's a bit of trivia. I've read that the alarm stalk will flash when the car is off, whether or not the alarm is armed, and the rest of the system doesn't even have to be installed! Installing just the stalk can function as a decoy alarm system.
United States View rkw's Pepper White & Black 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old Jan 13th, 2007, 07:31 PM   #8 (permalink)
CoolCarStuff
Flying Scotsman
CoolCarStuff's Avatar
Local Time: 11:44 PM
Question then...as we are talking stalks (ot...)
Can you replace the wiper stalk with a later one too...?
Does anyone know what sensor reports and what controls the low fluid led?
DJ
Scotland   Reply With Quote
Old Jan 13th, 2007, 07:40 PM   #9 (permalink)
MartinSSZ
Yellow and Proud
MartinSSZ's Avatar
DJ - I'd imagine that you can physically swap them over, but the level sensor in the washer bottle and the wiring for it won't be in place on cars built before January 05.
If you're desperate for the feature I'm sure you could fit the level sensor/swap your washer bottle to one with a sensor, and replicate the wiring to the stalk. Not sure if it's a direct feed from the sensor to the stalk or whether the BC ECU is involved...
Old Jan 13th, 2007, 08:56 PM   #10 (permalink)
CoolCarStuff
Flying Scotsman
..thanks for the reply...
I would imagine the BC will be involved... knowing our luck!
I did have a quick look at one, and it looked like the actual stalk had changes in the switches for front/rear wiper... need to have a closer look!
I guess we could even use it (or the other one) as a shift light... he he...
DJ
Old Jan 13th, 2007, 09:21 PM   #11 (permalink)
MartinSSZ
Yellow and Proud
MartinSSZ's Avatar
My research confirms that the BCU is indeed involved, and it changed at the same point so the older versions are unlikely to carry the functionality to support the level sensor
The sensor switch itself switches an earth path to the BCU, which then provides a 12V signal to the washer stalk to illuminate the LED.
There are a number of different types of stalk available, depending on:
* Rain sensing wipers/not
* Convertible (or GP) or not (presence of rear wiper)
* Washer level LED or not
So you might have seen a stalk with an LED but for a convertible or for rain-sensing wipers. Then again they might have changed it, but I don't recall any functional or operational difference between my Cooper (June 2003) and my brother's One (Feb 2005) which have the same wiper system (normal Hatchback non-sensing)
Old Jan 15th, 2007, 08:37 AM   #12 (permalink)
chris.lamb
chris.lamb's Avatar
I changed my left stalk for the post 2005 version with red alarm LED.
Its a simple job to wire this up to the right stalk and get both RED LED's to flash.
Looks very Night Rider !!!!!!!
Old Jan 15th, 2007, 07:14 PM   #13 (permalink)
CoolCarStuff
Flying Scotsman
Thanks Martin...good post...
Yes, it looks likethe one I saw must have had no rear wipe... I assumed that perhaps the later car used the front auto wipers to work the rear ...my 03 mcs has auto wipers and the rear is still manual... hence I noticed the difference....
Thanks for the info....
DJ
Old Jan 15th, 2007, 09:43 PM   #14 (permalink)
Eric_Rowland
I can confirm that. On my '04 I installed the system, and upon locking the red stalk flashed before the dealer had activated the system. I confirmed via jacking up the car (tilt sensor) before and after that the alarm had not been activated.
'04 IB/W #1,#2,#3, Nav w/Brit voice, HK, lapis leather, aux gauges, bonnet stripes, Ian's auto-up/GDO, full toggle rack
I've motored cross-country, have you?
United States View Eric_Rowland's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Light in end of wiper/indicator switch - bulb? mikeythemini Interior & Ice 2 Jan 29th, 2007 11:47 PM
WANTED Indicator Stalk with OBC button KrisMcGrath For Sale 21 May 3rd, 2006 04:56 PM
Trip Computer - You Know, 1 On the indicator stalk... LouieCoop Interior & Ice 8 Apr 2nd, 2006 01:52 PM
Removing indicator stalk (for OBC) ariharry Interior & Ice 5 Nov 17th, 2003 09:39 PM
what is the red button on the end of the wiper stalk? ChilliSteve Interior & Ice 8 Apr 30th, 2003 02:29 AM
