| MINI2 Regular | Tachometer data sheet Hi everybody, Bit of an odd question but does anybody have any type of data sheet or technical information on the tachometer? I require information on the frequency pulses in particular. Any help would be appreciated. ![]() |
| MINI2 Regular Join Date: Oct 2004 Location: Warwick Local Time: 11:00 AM
Offline | From MINI EBA. Instrument cluster MINI The display instruments in the MINI consist of the central instrument cluster and the additional instruments available as optional extras. Central instrument cluster The central instrument cluster contains the logic for all displays and indicator lamps. The control unit is diagnosable. As of software 15, a fault code memory is implemented. Additional instruments The optional additional instruments are linked by a separate CAN bus with the central instrument cluster. The instruments are only able to display values from the central instrument cluster. The control unit has only identification as a diagnostic function. In the different markets, the display functions between the central instrument cluster and the additional instruments can vary. Manipulation point The instrument cluster of the MINI has no manipulation point. After replacing the instrument cluster, do not forget coding and import of the data! |
| Build Sheet for Your Car....? | Brynster | General Discussion | 14 | Sep 24th, 2008 10:02 AM |
| Complete spec sheet for GP | kiriath | MINI Cooper S | 9 | Aug 22nd, 2006 01:43 PM |
| Spec sheet for UK?? | LMB | MINI Cooper S | 1 | Dec 23rd, 2001 08:08 PM |
