» Sponsors
» Sponsors
Go Back   MINI2 - MINI Forum > R50, R52 & R53 - First Generation MINI > Interior & Ice
Interior & Ice
For all interior and In Car Entertainment discussion
MINI2.com is the largest MINI Forum on the internet. Registered Users do not see the above ads.
Old Mar 28th, 2007, 12:39 PM
Minione7's Avatar
Minione7
John Cooper Works Cooper
Local Time: 09:22 PM
Send a message via MSN to Minione7
United Kingdom Male View Minione7's Chili Red & Black 2nd Gen MINI Cooper Profile
Smile Amp wiring help
Hi i was hopeing someone out there could help me. i am thinking of fitting my amp in to my mini one. what is the best way to get the power lead from the battery to the boot. is there a easy accesable grommet i can get to, to get the wite inside the car.
cheer
minione7
Old Mar 28th, 2007, 12:49 PM
ScottyBoy's Avatar
ScottyBoy
Obsessive Car Cleaner OCC
United Kingdom Male View ScottyBoy's Solid Black & Body Color 1st Gen MINI Cooper S Profile View ScottyBoy's MINI Profile Images
Ive looked extensively and cant find a hole to use! you will have to make your own. luckily enough ive got an S now and the battery is in the boot!
Old Mar 28th, 2007, 01:50 PM
Root Ginger's Avatar
Root Ginger
Amiga 500 to PS3 20 Years
Local Time: 08:22 PM
The grommit I used on my Cooper was on the drivers side by where the brake pipes are.
I stuck a straightened out coathanger through from the engine side attached the cable in the footwell with ducktape (it needs to be really well held on) and then pulled it out from the engine side. I then ran it under the trim into the boot.
It was acceptable in the 80's
Old Mar 30th, 2007, 12:07 PM
bright spark
England Male View bright spark's Chili Red & White 1st Gen MINI Cooper Profile
There is a gromet on the passenger side behind the glove box (box comes out easily) It is the entry for a big loom but there are free channels which are blocked by rubber moldings. Really it is easy you can feel them bonnet side behind the plate near passenger windscreen wiper (honest). Although i cut into speaker cables for mine all went pair shaped when starting the car. Need to earth amp and stereo at same point close to amp, so for the mo mini is amp less but i believe in the dream and it will happen oh yes!
Old Apr 1st, 2008, 07:45 PM
ajamesj
U ave just been Doopered
Anyone got pics of grommet or area in engine bay to interior for the live feed to amp had a look today and doesnt look that easy
Old Apr 2nd, 2008, 11:57 AM
chris.lamb's Avatar
chris.lamb
United Kingdom Male View chris.lamb's Chili Red & White 1st Gen MINI Cooper S Profile
In a RHD MCS the battery cable runs under the LHS Passenger sill trim panel, see here :-
http://images.caraudiomag.com/compet...board_view.jpg
From an article on ICEing your MCS
Its the thick RED cable in the photo.
It passes through the bulkhead behind the passenger glovebox (LHD car in photo!) and just outboard of the end of the heater airbox where the rest of the car harness passes through the bulkhead.
I would copy this layout for your AMP feed as by copying the MCS routing you should have less peoblems as there is sufficient clearance in a MC.
Last edited by chris.lamb; Apr 2nd, 2008 at 12:56 PM. Reason: added further details
Tags: , , , , , , , , , ,
Wiring an amp for sub woofer Volte Interior & Ice 7 Jul 22nd, 2007 11:55 PM
Best re-wiring plan for HU->amp, amp->speakers in US '05 MCS? testanley3 Interior & Ice 4 Feb 10th, 2007 04:03 PM
Wiring an Amp Crouchy Interior & Ice 1 Jan 14th, 2005 06:51 AM
Sharks Fin wiring & Mobile Phone: Q's & A's perl Interior & Ice 26 Sep 12th, 2003 06:07 PM
Wiring an amp Dom Interior & Ice 4 Jan 20th, 2002 06:49 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
