| Tags: radio |
| MINI2 Newbie Join Date: Feb 2005 Local Time: 03:02 AM
Offline | Speaker install help---- Positive and negative wire so i installed new speakers in my car and they sounds good i just want to make sure i didnt get the positive and negetive wires to each speaker mixed up. i think i wired the red lined wire to the positive terminal and the brown lined wire to the negative terminal. i know red is usually negative but they sounded ok and figured they wouldnt really work if it was the wrong way. ANYONE KNOW IF THIS IS RIGHT. |
| "I'm kind of a big deal" | ! I'm not sure which colour is which but there's a handy way to work it out using your standard speakers. Get one of those little square 9 volt batteries (probably any low voltage batt is ok) and connect its + and - terminals to your original speakers. If the speaker cone moves outwards, then the + and - are connected correctly, if it moves inwards they're back to front. You'll now know which is the positive and which is the negative terminal on your speaker. Armed with this knowledge you'll be able to look at the bmw connector and work out which wire was originally connected to which terminal and therefore which one was positive and which was negative. Tadaaaaa! |
| Speaker Wire colours | Jammy T | Interior & Ice | 0 | Jan 11th, 2005 10:51 PM |
| negative coil wire color? | presurized mini | Wheels, Tyres & Brakes | 1 | Oct 8th, 2002 09:38 PM |
| Rear speaker wire tap location needed | jbramhall | Interior & Ice | 3 | Aug 16th, 2002 09:48 AM |
| New speaker wire into door HOW!?!?!? | jmardy | Interior & Ice | 7 | Jul 30th, 2002 11:17 PM |
| Amp install in boot, speaker wire run ideas needed. | jmardy | Interior & Ice | 12 | Jul 17th, 2002 09:56 PM |
