Adam's Polishes
Tags: ,
Old Sep 10th, 2007, 07:26 PM   #1
monkeyone
monkeyone's Avatar
Local Time: 11:44 PM
Send a message via MSN to monkeyone
Question Sat Nav voice gone awol
Hi, I am wondering if anyone can help. My car went into the stealers to get the ariel cable replaced (don't ask, long story!) as part of the process they ended up replacing the head unit for the updated model (Nice, if i hadn't just bought one from the classifieds!). Since I have got it back the sat nav voice has stopped working, both the nav and stereo seem to work fine and i have checked the volume in the settings. The stereo volume mutes slightly as if it is going to say something but doesn't! I have taken the h/u out and checked the connections but no joy .Can anybody point me in the right direction or offer any tips? I really dont want to have to take it back to the stealer only for them to feck up something else!
Old Sep 10th, 2007, 08:54 PM   #2 (permalink)
rkw
Local Time: 03:44 PM
When they installed the new head unit, they might not have reconnected the harness that includes the Nav voice. It plugs into the far left (volume knob) side at the rear of the unit. That connector is usually there only when Nav or aux input is installed.
United States View rkw's Pepper White & Black 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old Sep 11th, 2007, 08:15 AM   #3 (permalink)
monkeyone
monkeyone's Avatar
I have got an iPod adaptor which is connected on the left hand side in place of a white connection. Is the nav connection separate to this one?
Old Sep 11th, 2007, 08:40 AM   #4 (permalink)
rkw
I am referring to the connector C for Nav in the following diagram. Your iPod is probably on connector B.
Edit: that's assuming you are using an actual iPod adapter, not connecting to the aux input.
Old Sep 11th, 2007, 03:36 PM   #5 (permalink)
monkeyone
monkeyone's Avatar
Yes thats correct it is an actual ipod adaptor not aux. I haven't got that connection there which is probably the root of the problem. Do you know where this cable comes from? Is it the nav unit under the seat or the screen? Any idea about cable colours or colour of the connection end?
thanks
Old Sep 11th, 2007, 04:35 PM   #6 (permalink)
rkw
The cable should be there. My guess is that they forgot to reconnect it to your new head unit and it is hanging loose somewhere in back of the stereo.
Old Sep 12th, 2007, 09:59 AM   #7 (permalink)
monkeyone
monkeyone's Avatar
I dug this up yesterday, anyone know if this is the same issue?
p.s. have to post link in new post has haven't made 5 posts yet
Old Sep 12th, 2007, 09:59 AM   #8 (permalink)
monkeyone
monkeyone's Avatar
Here is the link, dealer is not being particularly responsive as usual.
http://www.mini2.com/forum/interior-...-tmc-work.html
Old Sep 12th, 2007, 06:14 PM   #9 (permalink)
rkw
What year is your MINI?
To summarize what I see in that thread:
  • If the car is an earlier year (e.g. 2003) and you install a newer style headunit with TMC, you may lose the Nav voice. The remedy is to run a new 2 wire cable from the Nav unit to the headunit.
  • If you use a headunit without TMC (e.g. Alpine), Nav voice should not be affected. Also if you have a newer car (e.g. 2006), you should be able to use any OEM head unit (with or without TMC) without affecting the Nav voice.
Old Sep 12th, 2007, 09:44 PM   #10 (permalink)
monkeyone
monkeyone's Avatar
2003 with new head unit.That is what I thought. Had a look on newministuff but couldn't see the cable so guess it is a DIY job. Trying to get the dealers to fix it seeing as it is their **** up.
Sat Nav Voice Volume moog5 2nd Gen Interior & Ice 4 Jun 21st, 2007 06:15 AM
Sat Nav Voice Commands BRADDE 2nd Gen Interior & Ice 0 Nov 29th, 2006 10:45 PM
No voice on Sat Nav - help? quenching Interior & Ice 7 Oct 2nd, 2006 07:30 AM
Sat Nav Voice Accents Windshadow Interior & Ice 153 Apr 16th, 2006 03:22 PM
Male voice for SAT NAV? chuckd Interior & Ice 0 Mar 2nd, 2004 07:29 PM
