Performance Torque
Tags: ,
Old Nov 9th, 2007, 02:26 PM   #1
Alexios
Local Time: 05:01 AM
gauges that have the most oem look
Hi there folks
Have been wanting to install gauges (boost/oil temp) for a long time now. I am pretty set on the alta upper gauge pod.
Alta Mini Performance - Dual Gauge Pod
Which gauges match the oem look best, both considering the background color as well as when lit at night?
Another thing I was wondering is the difference between mechanical and electrical boost gauges. How does the electrical gauge sense the boost/vacuum? What do you think is better/easier to install.
Please post pictures of your setup.
Alex
Norway   Reply With Quote
Old Nov 9th, 2007, 07:40 PM   #2 (permalink)
sam_a156
Flying Finn
sam_a156's Avatar
Send a message via Skype™ to sam_a156
I have been thinking of doing exactly the same...very interested in hearing the answers too.
Edit: Alexios, you might want to check this MINI COOPER :: North American Motoring - show off your gauges here! pics here!
Last edited by sam_a156 : Nov 10th, 2007 at 07:11 AM. Reason: Found an interesting thread from NAM
Poland Male View sam_a156's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 10th, 2007, 10:45 AM   #3 (permalink)
Darrin
Mighty Mouse
Darrin's Avatar
Local Time: 01:01 PM
Here's a picture of my Autometer boost and A/F ratio gauges installed on the OEM gauge panel. They have shiny chrome bezels and real carbon fibre faces which match the chrome line interior and carbon dash - of the Parklane - nicely.
I used an amber LED in the boost gauge and that matches the factory lighting quite well. However, if you use the OEM gauge panel you really dont need to wire in the bulbs as the area beneath the centre console is illuminated already.
My boost gauge is mechanical in operation and under hard acceleration with sudden increases in boost you can hear the internals working, but its not obtrusive and now I quite like the sound. An electrical boost gauge will be quite in operation but will also require additional wiring.
ID:	139265  Click image for larger version
ID:	139266  Click image for larger version
Australia Male View Darrin's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 10th, 2007, 04:42 PM   #4 (permalink)
Alexios
what kind of boost levels are you getting? have a stock pulley but will change to -17% sortly. Is a gauge that goes to 20PSI enough or should get one that goes to 30 psi?
Is there a bigger chance of a leak with a mechanical boost gauge?
Was it easy to route the tubing through the firewall?
Old Nov 10th, 2007, 05:01 PM   #5 (permalink)
ScottyBoy
Obsessive Car Cleaner OCC
ScottyBoy's Avatar
Local Time: 04:01 AM
Alexios - im running a set of prosport Oil temp and Boost gauges although there a smoked colour at night the look very good, hears a vid.
Im running an Alta 15% pulley and 2% alta crank pulley and im seeing around 16 - 17 PSI max id recommend a gauge that goes to 30 PSI.
The difference between mechanical and electrical is that on an electrical gauge the tubing goes to a sensor and then the sensor leads to the gauge, mechanical gauge - the tubing goes directly to the gauge.
Ive got a fitting guide hear that i made with pics.....http://www.mini2.com/forum/interior-...stall-diy.html
Scott
Old Nov 10th, 2007, 11:23 PM   #6 (permalink)
steve11
Mad Modder
steve11's Avatar
I have genuine Mini boost & volt gauges fitted.They are made for Mini by Stewart Warner & are branded Cooper S on the guage faces.They match the OEM speedo & tacho perfectly in every respect.
Australia Male View steve11's Electric Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 11th, 2007, 12:22 AM   #7 (permalink)
Darrin
Mighty Mouse
Darrin's Avatar
I'm currently running the stock pulley and maximum boost is between 11.5 and 12 psi. However, my alta V2 -15% pulley is sitting in the study ready for installation and I hope to see the boost increase to about 15 psi. Hence, a full scale reading of 20 psi on my boost gauge will give me better resolution than a 30 psi model.
I don't think that there is any incease in the chance of boost leaks with a mechanical gauge both types use pipes to connect into the intake manifold. However, I ran the boost line in split conduit just to be on the safe side.
No problems getting the tubing through the firewall there is a rubber boot on the drivers side (RHS models) which makes the job easy.
Old Apr 25th, 2008, 08:50 AM   #8 (permalink)
MINIdriver85
Hi, how did you fit them there, using the Alta gauge pod or something OEM?
Italy   Reply With Quote
Gauges jasonbarnard Interior & Ice 8 Jan 10th, 2007 06:22 AM
OEM gauges - never seen these before Babes Interior & Ice 4 Nov 9th, 2006 05:15 PM
Gauges Nick-o Interior & Ice 1 Jun 3rd, 2004 09:45 PM
gauges MINIS2003 Interior & Ice 1 Apr 14th, 2004 09:07 PM
OEM Additional gauges instructions? John MCS Interior & Ice 0 Oct 17th, 2003 09:30 AM
