Visit Mini Mania UK
Tags: ,
Old Jan 28th, 2008, 04:41 PM   #1
JAMIE1131
JAMIE1131's Avatar
Local Time: 08:14 AM
John Cooper Works Seats
Hi!
I'm bidding on this seat on ebay JOHN COOPER WORKS SEAT FOR BMW MINI R50 MODEL NEW on eBay, also, Mini, Car Parts, Cars, Parts Vehicles (end time 01-Feb-08 15:51:24 GMT)
To replace one of mine which is a touch worn out, does anybody know how hard they are to fit and also if its possible to put the heaters from my seat into this one?
Cheers,
Jamie
United Kingdom Male View JAMIE1131's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 28th, 2008, 07:29 PM   #2 (permalink)
ScottyBoy
Obsessive Car Cleaner OCC
ScottyBoy's Avatar
Jamie...
They are a dodle to fit really.
1, Remove the 2 wiring harness under the seat ( Yellow & Blue)
2, If you have a look at the 4 mounting screws under the seat in each corner, you need a small socket set and torx bit to undo them, and remove the seat.
3, if the new seat does not come with the seat belt pre tensioner then undo the torx bolt on your old seat on the pre tensioner and snip off the zip ties then replace on new seat.
4, Replace seat and 4 bolts,
5, Clip the 2 plugs back together, if you do that before you turn the ignition on then you wont have the airbag light come on.
Hope that helps,
Scott
Old Feb 2nd, 2008, 02:41 PM   #3 (permalink)
Hugo
Hugo's Avatar
Chris @ Woodman sent me fitting instructions with JCW harness slots. I'll see if there is anything to add to Scottyboy's
Northern Ireland Male View Hugo's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
John Cooper Works Black Works John Cooper Works & GP 0 Nov 30th, 2005 03:30 PM
John Cooper Works Seats... a supplier? hunkey dorey Interior & Ice 1 Feb 5th, 2005 05:44 AM
John Cooper Works Seats - eBay El Gordo General Discussion 6 Jan 25th, 2005 08:07 AM
how much for john cooper works seats? cuprar MINI Cooper S 3 May 2nd, 2004 10:18 PM
John Cooper Works Sports Seats. Paul John Cooper Works & GP 80 Feb 4th, 2004 01:55 PM
