Old Mar 16th, 2008, 02:59 PM   #1
specky001
specky001's Avatar
Local Time: 04:31 AM
Airbag Reset Light?? Can Any Garage Do It Or Just Bmw??
I've just changed my steering wheel, and airbag and the airbag light has come on the dash! i knew this would come on, but havent thought about who can reset it??
Can only BMW MINI garages do this? or any garage with a diagnostics machine??
www.nottsminiclub.co.uk
Old Mar 16th, 2008, 04:36 PM   #2 (permalink)
mab01uk
Loads on how to do this in the faults and fixes forum section under airbag light reset/ petition etc,. It is cheaper to buy a B200 SRS Reset tool on Ebay for around £50 to do it yourself. Any garage will charge more than this every time.........once you buy the tool you can use it whenever required.
(The airbag light only normally stays on if you switch on the ignition when something in the airbag circuit is disconnected even for a moment but once this happens it stays on until you reset using a suitable tool.)
Old Mar 16th, 2008, 04:50 PM   #3 (permalink)
specky001
specky001's Avatar
ah cool, thanks v much, but most other garages can do it anyway??
Old Mar 16th, 2008, 05:24 PM   #4 (permalink)
mab01uk
Yes if they have the right diagnostic tools but some independent garages just call in a mobile service man to do the job anyway (similar to mobile air conditioning specialists) as the demand may not justify them having in house facilities for such work.
Old Mar 16th, 2008, 10:07 PM   #5 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Old Mar 16th, 2008, 10:25 PM   #6 (permalink)
specky001
specky001's Avatar
Spalding, south lincolnshire!!
Airbag Light reset sofware rgn Faults & Fixes 30 Oct 4th, 2007 10:34 PM
can the airbag light be reset sillycar gt4cs Faults & Fixes 7 Mar 13th, 2007 07:20 PM
Airbag Fitting and Airbag Light Reset Westy_1985 Faults & Fixes 3 Sep 30th, 2006 05:31 PM
how do i reset the airbag light? sarahmarck Faults & Fixes 6 Sep 5th, 2006 06:10 PM
Does anyone know how to reset an airbag light? onrails Faults & Fixes 10 Aug 8th, 2005 07:30 PM
