Tags: , ,
Old Apr 4th, 2008, 04:12 PM   #1
BlackEyedPea
BlackEyedPea's Avatar
Local Time: 04:03 AM
door sills
i currently have aero side skirts but there are no side sills.
i still have my old cooper side sills...can i take them off and stick them on the aero sills?....or would i have to do some extra work?.....(if they fit??)
Old Apr 4th, 2008, 04:36 PM   #2 (permalink)
Randall Raines
MINI & other ½ both whine
Randall Raines's Avatar
If by "side sills" you mean the aluminium plate with the COOPER S / COOPER / ONE / MINI on it, I have fitted them for people too Aero-kits in the past, they do sit a little proud because the Aero-kit has a flat surface & the original sill-covers have a recessed area for the trims .
You have to be very careful removing used ones from the old sill-covers, the Main Dealers wouldn't bother swapping them over as they just dispose of them and replace them with new ones if needed as they're easily damaged & there's a little messing about involved.
They are stuck on with double sided tape, you will need a sharp knife or scraper to remove them as you have to try and not bend them (just pulling them etc...) as they bend very easily (can also go white when the aluminium is bent) and never go back on properly once bent and they easily mark or dent from underneath using implements / tools trying to remove them, so you have to be quite careful.
Fitting used ones, you will have to clean off all the old tape replacing it with new and just stick them on making sure the surface is clean, sometimes helps if the surface is slightly warm (hair-dryer), and make sure they're straight / central as you have no recess to guide you .
Mine's the one on the left.
Last edited by Randall Raines : Apr 4th, 2008 at 06:11 PM. Reason: added or COOPER / ONE / MINI etc... etc... in wording.
Old Apr 4th, 2008, 04:44 PM   #3 (permalink)
BlackEyedPea
..i have some double-sided (padded) tape (about 2mm thick)..is that ok?
also.. is there a chance it could scape on tthe door??
Old Apr 4th, 2008, 04:45 PM   #4 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 08:03 PM
DIY: How to fit 'S' side skirts to a Cooper or One
Old Apr 4th, 2008, 04:54 PM   #5 (permalink)
BlackEyedPea
Quote: Originally Posted by MINIAC (original)
...??..do i have to remove the skirt to put on a door sill????...oh and its a cooper sill not an "s" (if that makes a difference)
Old Apr 4th, 2008, 05:26 PM   #6 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
The DIY has pictures showing how to remove the strips from your Cooper sills and clean the glue residue from the strips. Once you've done this it's a matter of using double-sided tape to put the Cooper strips on top the Aero sills.
Door sills Chrisone Interior & Ice 0 Aug 20th, 2007 02:10 PM
Door sills Tracewhy Interior & Ice 5 Jun 29th, 2007 08:38 PM
Illuminated door sills.. Mini Me GB Interior & Ice 28 Nov 20th, 2005 05:24 PM
Illuminated Door Sills... whokilledkaji Interior & Ice 11 Oct 10th, 2005 11:22 AM
Door sills question Lestat MINI Cooper S 1 Feb 3rd, 2005 12:01 AM
