FOMSPORT
Tags: ,
Old Jul 7th, 2008, 05:01 PM   #1
nutter28
nutter28's Avatar
Local Time: 12:40 AM
United-Kingdom Chrome line interior
Hi
Has anybody purchased any of the chrome line interior/cockpit kits from ebay? They look fab but are they any good & are they lasting well?
Old Jul 7th, 2008, 06:15 PM   #2 (permalink)
M.O.S
MINI One Seven
Doubt it, I mean I haven't seen them, but I wouldn't want to buy something which I haven't seen, or seen an equivalent product. I know that the dealers are now offering it as an accessory - try a quote from them!
The Original MINI One Seven
Old Jul 7th, 2008, 07:15 PM   #3 (permalink)
mikeythemini
I can't get no sleep
mikeythemini's Avatar
If its for a 1st gen mini then we stock the genuine chromeline interior as a kit or seperate. Perfect fit as its made by Mini - NewMINIStuff.com
Old Jul 7th, 2008, 07:35 PM   #4 (permalink)
Mejy Poo
Mejy Poo's Avatar
Mikey there are loads for the R53 but when are they going to be available for the R56? I called Woodmans for a quote and it was ridiculous Knew i should have specified it
United Kingdom Female View Mejy Poo's Astro Black & Body Color 2nd Gen MINI Cooper Diesel Profile   Reply With Quote
Old Jul 7th, 2008, 07:36 PM   #5 (permalink)
SoggyCornFlakes
Awwww %%%% it!
SoggyCornFlakes's Avatar
Send a message via MSN to SoggyCornFlakes
a few folks on here have bought from eBay - I did and loved it. But some insist on BMW only and have that only. It's horses for courses but I dont think you can tell the difference once they are installed.
England Male View SoggyCornFlakes's Pepper White & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 7th, 2008, 07:48 PM   #6 (permalink)
M.O.S
MINI One Seven
How did you get that? More to the point, how difficult is it to fit?
Old Jul 7th, 2008, 08:02 PM   #7 (permalink)
coupe-se
Derv? Nein Danke.
Notch up another person wanting an R56 chrome interior kit.
Is an aftermarket kit even on the horizon?
United Kingdom Male View coupe-se's British Racing Green & White 2nd Gen MINI Cooper S Profile   Reply With Quote
Old Jul 7th, 2008, 10:42 PM   #8 (permalink)
mab01uk
One of several threads on how to fit, etc:-
http://www.mini2.com/forum/interior-...elf-fit-2.html
March 2008 issue of Modern MINI magazine has a comprehensive step by step photo fitting guide by MiniMatt for the OEM interior chrome pack including dismantling the speedo and rev counter..........starting on page 42.
Old Jul 7th, 2008, 11:04 PM   #9 (permalink)
Chiu
Chiu's Avatar
Bear in mind that you can get the genuine replacement bits like NewMINIStuff supply or some cheaper bits which sticks on over your existing trim using double sided sticky pads and such. I went for the genuine parts plus a few other cheaper chrome bits for things like the rear cup holder, electric mirror button surround, door lock rings and such (which I believe aren't available as genuine parts).
I don't know how the eBay ones fair but it's worth checking whether they are replacement or stick-on bits before you buy them so you can check if you're paying a decent price.
Not many people will notice any difference between the replacement and stick-on bits. However, the stick-on bits probably don't sit flush with things like the revometer and cup holders because you're effectively adding another layer of trim to the existing trim. Guess the end result is essentially the same
Fitting them was easy enough, although I did have a guide from Moderm MINI magazine to follow
United Kingdom Male View Chiu's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 7th, 2008, 11:51 PM   #10 (permalink)
Mosposco
it's not easy bein' green
Mosposco's Avatar
I've just fitted a set of the Ebay ones to my R50 and I would say for the money they are pretty good.
Obviously, as Chiu says,they fit over the originals rather than replacing them and a couple of the parts aren't a 100% fit, but on the whole the quality appears good and the for the money the result is more than satisfactory.
I'll probably replace the parts that aren't a perfect fit with genuine ones at some point in the future, but for now they'll do just fine
Old Jul 8th, 2008, 07:09 AM   #11 (permalink)
mini33
Perfectionist Cooper S
mini33's Avatar
I have the full kit of ebay, the stick on version & i am 100% satisfied mine all fit flush & look great. I think the hole kit cost me about £50-60
You got to get it as you wont believe how much of a differnce it makes
I liked the idea of the stick on version as you can remove & use again just for the price of some sticky back plastic.
I found the sticky version very easy to apply you just peel of the sticky back,back off & place over the orginall its as easy as that. Obviosly the door pins are push ons.
Depends on what you want
Hope that helps
Old Jul 10th, 2008, 05:40 PM   #12 (permalink)
crofty136
crofty136's Avatar
i'm not keen on the chrome kit myself, think it looks a bit OTT, From Scotthall leeds, my local mini dealer i know i could get the parts for £79.85, Quite reasonable i think
Old Jul 10th, 2008, 07:06 PM   #13 (permalink)
M.O.S
MINI One Seven
Sounds a good price - does that include everything? Also, I don't suppose you happen to know how much fitting was do you?
Old Jul 11th, 2008, 04:56 PM   #14 (permalink)
crofty136
crofty136's Avatar
I assume it was for everything, he took my reg number and so on and told me that price, i have the interior chrono pack so the rev counter and speedo are together, might even be slightly cheaper without
Old Jul 11th, 2008, 05:02 PM   #15 (permalink)
M.O.S
MINI One Seven
Ah right, sounds good to me. Don't suppose you know how much it was to fit do you?
Chrome line interior maryjane 2nd Gen Interior & Ice 15 Apr 10th, 2008 07:50 AM
chrome line interior twentysecondstogo MINI Cooper Diesel 8 Jun 23rd, 2007 06:56 AM
Chrome line interior? claz 2nd Gen Interior & Ice 16 Mar 16th, 2007 10:18 AM
Chrome Line Interior ranzaboy 2nd Gen MINI Cooper 8 Dec 3rd, 2006 12:35 PM
Chrome Line Interior r34ver MINI One 12 Nov 14th, 2004 11:32 AM
