» Sponsors
» Sponsors
Go Back   MINI2 - MINI Forum > R50, R52 & R53 - First Generation MINI > Interior & Ice
Interior & Ice
For all interior and In Car Entertainment discussion
MINI2.com is the largest MINI Forum on the internet. Registered Users do not see the above ads.
Old Dec 6th, 2002, 12:29 AM
duboy
Local Time: 08:37 PM
Send a message via ICQ to duboy Send a message via AIM to duboy
United States View duboy's Solid Black & Body Color 1st Gen MINI Cooper S Profile
removing sticker residue from trim
hey all, my roomate peeled off the airbag sticker that is smack in the middle of the passenger side airbage compartment. but it left a nasty sticker residue. how can i remove it without affecting the plastic compartment cover? i would use something like goo-gone or some other solvent, but i'm afraid the solvent will mar the plastic any suggestions?
Old Dec 6th, 2002, 07:02 AM
aus-tim powers's Avatar
aus-tim powers
Man of Mystery
Local Time: 09:37 PM
United Kingdom View aus-tim powers's Chili Red & White 1st Gen MINI Cooper S Profile
Adhesive probs!!
As a signmaker i use brake cleaner from an aerosol to clean
adhesive residue from pvc or painted surfaces 99% successful.
It costs about £3 over here.
Simply soak a few seconds and wipe off gently.
(I suggest you try it first on a non visible area)
Tim
[img]http://www.mini2.com/gallery/personal/aus-timpowers/sig_no_3.jpg[img]
MCS,Chili pk,Tints,Eibachs,Aeroskirts,PIAA spots,Wunoff Exhaust system.
CHECK OUT MY GALLERY!-Click below
Old Dec 6th, 2002, 07:17 AM
cordial's Avatar
cordial
Switzerland View cordial's British Racing Green & Black 1st Gen MINI Cooper S Profile
Use a paintwork tar remover. They leave most plastics intact and work wonders on sticker residue.
Cooper S BRG/B, Chili, DSC, Overheated seats, auto A/C, OBC, heated mirrors/jets, Boost + CD. delivered 24.09.02 (ordered 11.09.01). MAX tint on back 3 windows. 17" S-Lites with Dunlop summer run-flats. 16" X-Lites with Goodyear Ultra Grip run-flats for winter. Remus exhaust (LOUD !).
Old Dec 6th, 2002, 08:31 AM
rogerswt's Avatar
rogerswt
Local Time: 03:37 PM
Send a message via AIM to rogerswt
United States View rogerswt's Indi Blue & White 1st Gen MINI Cooper S Profile
Re: removing sticker residue from trim
I had the same problem and concerns. WD40 worked perfectly. Took it off easily - no harm to the plastic.
Old Dec 6th, 2002, 09:58 AM
Pamlico's Avatar
Pamlico
Dead Man's Curve? Feh.
Local Time: 04:37 PM
Send a message via AIM to Pamlico
United States Male View Pamlico's British Racing Green & Black 1st Gen MINI Cooper S Profile
This has been discussed a few times here. Before using any chemicals on the residue try using the back side of the sticker you removed. It's the same material as is already on the dash so ono concerns over damage. Worked very well for me.
That said, WD40 should also work fine.
Old Dec 6th, 2002, 10:01 AM
smiffy's Avatar
smiffy
Send a message via MSN to smiffy
Wales View smiffy's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Furniture polish does the trick
S for Smiffy
"Kids in the front seat cause accidents, accidents in the backseat cause kids!"
Old Dec 6th, 2002, 02:11 PM
R1's Avatar
R1
Addicted to Speed!!
United Kingdom Male View R1's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
A lot of adhesives used on internal stickers are water based glues. A simple rub with hot plain or soapy water should remove it if this is the case.
Old Dec 6th, 2002, 07:27 PM
BruceK's Avatar
BruceK
Moderator & Sponsor
Local Time: 02:37 PM
Avoid chemicals. You simply don't need them.
I wouldn't recommend using any sort of solvent on the plastic. Solvents could cause damage to the plastic that may not be immediately visble, but could show up later as discoloration or brittleness.
The best way to get rid of the sticker residue (using no chemicals or abrasion) is to use the back of the sticker itself and reapply it and then quickly lift it off in an attempt to pull the residue off (cohesion to the adhesive sticky stuff on the back of the sticker is stronger than the adhesion to the dashboard). Repeat until the residue is gone.
You can do the same thing with simple masking tape. Press it on over the residue and the lift it off quickly. Repeat as necessary using fresh pieces of tape and the sticky residue will soon be all on the tape with none on the dashboard.
Removing Inside rear window sticker.... superdupercooperS Interior & Ice 9 Sep 5th, 2006 09:47 PM
Removing Sticky Tape Residue from Aero Skirts? AidenL Exterior 3 Apr 2nd, 2005 09:41 AM
Removing Dealer Sticker From Rear Window El Gordo General Discussion 20 Oct 27th, 2004 03:49 PM
Removing Sill Plate Adhesive Residue hairyhen Exterior 6 Jul 27th, 2004 11:09 AM
dash sticker residue clean up? IBMiniG General Discussion 14 Nov 7th, 2002 09:48 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
