Performance Torque
Old Apr 3rd, 2003, 02:49 PM   #1
musicman
Local Time: 05:00 AM
HK with new head-unit: possible solution
I wanted to replace the Boost-HeadUnit with an Alpine 7894RB Headunit but ran into a lot of problems. Although the Alpine could be installed and received power and antenna feed, the HK amplifier refused to turn on.
I've found a possible solution for this problem on a German internet site.
To solve the problem with the HK-amplifier you should directly connect the HK-amplifier to the speaker outputs of your new Headunit. A "High-in" is absolutely necessary.
Does anyone have any experience on this matter?
Belgium   Reply With Quote
Old Apr 3rd, 2003, 03:00 PM   #2 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
Local Time: 06:00 AM
What is the point in just changing the head unit ?
Your not going to improve the performance of your system as the amplifier will control volume output and clipping of the speakers. All you'll achieve is the loss of extra K-bus functionality (eg. DSP setting etc.) and you'll gain some flashing lights which will be more appealing to theives and won't match your cars interior.
Mmmmm - interesting justification...
Old Apr 3rd, 2003, 03:10 PM   #3 (permalink)
musicman
I know understand why BMW gives so little information on the HK-system: it is terrible.
Unfortunately, I based myself on the reputation of the HARMAN products and ordered the HK-system in my MCS: big mistake.
The Boost Head-Unit absolutely sucks, and is in now way theft-proof, since you can't remove the front.
The Alpine Head-Unit has full DSP capabilities which can match the DSP of the HK system. It also has MP3 compatibility and a DAB (XM in USA) controller. You can detach the front of the Alpine Head-Unit, so theft is less likely than is the case with the Boost Head-Unit.
The front of the Alpine Head-Unit is aluminium and therefore compatible with the aluminium look of my dashboard.
I'm stuck with the HK system and have at the moment no ambition to remove the complete system (amp and speakers).
Old Apr 3rd, 2003, 07:13 PM   #4 (permalink)
laz
Local Time: 03:00 PM
i think just change your exhaust .. then you'll be too busy listening to it you wont worry about the HK .. its not that bad ..
Australia   Reply With Quote
Doing my head (unit) in! t400 Interior & Ice 3 Mar 6th, 2007 08:19 AM
Head Unit ???? Jamesr022 Interior & Ice 6 Jul 9th, 2006 07:06 PM
Head Unit |MD|Cooper| Interior & Ice 1 May 7th, 2006 10:55 AM
Which Head Unit Should I Go For??? BenMW Interior & Ice 9 Feb 8th, 2004 07:18 PM
head unit causing my head to spin!! kars Interior & Ice 10 Oct 29th, 2003 03:54 PM
