Adam's Polishes
Old Nov 19th, 2003, 12:40 PM   #1
Spacer
Local Time: 04:32 AM
H/K rear speakers
Firstly, let me apologise as the H/K subject comes up all the time. I have just finished searching on this matter, before someone suggests it.
My question is this: Does anyone else have very little output from the rear speakers on h/k mode (and instrumental/electronic). Most of the bass seems to be produced from the lower speakers in the front, and not much from the back (you can put your hand on the rear grille, and they don't seem to be doing much at all compared with the lower fronts). When I change to either Spatial or Festive the rears sound fine, so there's no problem with the connection. I'm just wondering if anyone else has experienced this? Maybe its just my music doesn't have low enough freqs?
United Kingdom View Spacer's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 19th, 2003, 02:38 PM   #2 (permalink)
GBMINI
Local Time: 11:32 PM
Common subject. Surprised you could not find much about it!
Ears have difficulty localizing the low frequencies.
Simple test - adjust fade to front only which will silence the rears. Compare with what you normally hear.
NOTE: the fade on HK is a bit wierd, but it does do what you expect when fully front or rear.
Ian C. Gloucester, MA, USA (UK expat) driving GPMINI and Convertible GBMINI#6
United States Male View GBMINI's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Nov 19th, 2003, 02:47 PM   #3 (permalink)
Spacer
Yea, thanks for the reply. I'd found tons of threads, but it was all 'oh, my H/K has too much bass, etc', and plenty about the rear speakers only producing bass. I'll try it tonight when I get home fiddling with the fader, but as I say, most of the bass seems to be done by the front speakers. I do understand about the fader being a bit odd, as instead of fading, it actually increases/decreases the bass in h/k mode. It just seems stange that really the front speakers seem to be doing all the work, while the backs don't do much (even when they are meant to be doing all the low freqs, it seems like the fronts are doing it). As I say, I'll try fiddling more later. Its probably just me though, as whatever way its doing it, it still makes a great noise
Old Nov 19th, 2003, 06:04 PM   #4 (permalink)
Spacer
Right. I've had a wee play, and it all sounds fine. Its just I thought that the rears would take more share of the overall frequencies than they currently do. From what I can see, its the lower fronts that make most of the noise. Oh well. Whatever works!
Old Nov 19th, 2003, 09:27 PM   #5 (permalink)
GBMINI
Play with it more ... I am settled on the "spatial" setting now, which gives a reasonable all-round sound. More like what I expect from a car stereo.
Old Nov 19th, 2003, 09:48 PM   #6 (permalink)
Spacer
Again, thanks for replying. I think its just one of those things that takes quite a bit of playing with. Shame the manual doesn't help more, but the H/K review that is floating about is a great help.
Rear Speakers Skim Interior & Ice 34 Aug 16th, 2006 11:33 AM
How do i get at the rear speakers??Help Please wo53 rks Interior & Ice 4 Aug 4th, 2006 07:18 PM
Rear Speakers yellow perril Interior & Ice 2 Feb 20th, 2006 01:11 PM
HK pack, and rear speakers Andyman Interior & Ice 3 Dec 14th, 2003 09:51 AM
Best speakers for the rear!? ultamotiv_coog Interior & Ice 1 Oct 23rd, 2003 05:11 PM
