Old Dec 21st, 2003, 04:48 PM   #1
nickp
Local Time: 06:23 AM
DIY Aux Input for 2004
Call me cheap and/or impatient, but I'm curious about rigging up my own Aux input rather than spend $40 plus shipping for the official kit.
I read through the entire thread about the DIY work they did for the 2003:
http://www.mini2.com/forum/showthrea...ight=aux+build
And I'm going to give that a shot. My question: Did anyone find a way to get around the issue of the AUX not showing up while charging an iPod? I'll use the Ground Loop Isolator from RadioShack if needed, but at that point it almost makes more sense to purchase the kit.
Must stop adding music to my MINI... http://nickpresley.com/xm
Thanks,
Nick
United States View nickp's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Dec 21st, 2003, 08:13 PM   #2 (permalink)
CurtP
CurtP's Avatar
Local Time: 08:23 AM
I made the aux adapter and I ended up buying the official MINI adapter anyway. The one I made worked, but seemed a bit dodgy after I had spliced in the ground loop isolator. The isolator was $15-$20 from RatSak by itself, plus you'll need the connector that fits in the back of the radio. My biggest complaint about the RatSak GLI is the size -- it's huge.
I believe it cost me less than $40 shipped from Classic -- if I remember right, it was around $35. Still be more than what you want to pay, but worth it IMO.
BTW, if you want the correct connector that goes on the back of the radio, I happen to have an OEM one. I believe it uses the same type of pins that is used in the computer connectors. My new MCS has satnav, so I pulled the pins out of the aux adapter and plugged them into the existing plug.
United States View CurtP's Pepper White & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 22nd, 2003, 05:09 PM   #3 (permalink)
ToreB
ToreB's Avatar
Local Time: 12:23 PM
By the way, does any have a electronic schematic of the aux "wire" assembly? By finding out what's in this and the loop isolator we can make this ourselves for a few €uros...
Pictures of aux wire components can also help.
Regards, Tore
Norway View ToreB's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 26th, 2003, 08:18 PM   #4 (permalink)
nickp
I went ahead and built the AUX cable using the method from this site:
http://www.neeshil.com/nsite/miniaux.asp
Install was quite easy, although I wasn't so sure the panel under the steering wheel was going to pop off at first, I really had to give it a good tug. Even though the plug you make doesn't clip in like the official piece, it fits well and doesn't move once in place.
I got the Belkin iPod charger for Christmas, so I did purchase the Ground Loop Isolator from RadioShack for $15, plus a second Y adapter (RCA Stereo to Mini) for $5. I purchased the second adapter so I didn't have to splice in the wire (seemed to be an issue for CurtP in this thread). About $20 more than I wanted to spend, but it works perfectly. The Ground Loop Isolator isn't as big as I thought it would be, that main segment is about the size of a "D" battery. I'll tuck it all underneath and put up some pictures a bit later.
Overall, I saved about $20 and didn't have to wait for shipping. That being said, I mainly did it because I enjoy little projects like this.
-Nick
Old Jan 18th, 2004, 12:55 AM   #5 (permalink)
DrMarkie
Well I just drove to Tate MINI of Annapolis and picked up an adaptor...... $40. I asked if they did installation and they quoted me $224 because "it takes 1.5 to 2 hours to fit".
So I thought all the advice out in these forums must be nonsense. But I gave a quick tug on the panel beneath the steering wheel, it dropped down and then I reached round the back of the head unit turned the clip part uwards and it went straight into the back of the radio. I was done in about 45seconds. I didnt install the socket, but I dont really like the look of it all that much. I prefer just a wire going from the the side of the under steering wheel panel straight into the ipod in the cup holder.
So thanks to all the great advice on here I saved $180.
I owe you all a beer.
Old Jan 18th, 2004, 11:53 AM   #6 (permalink)
GadgetGav
gadgetmeister
GadgetGav's Avatar
1.5 to 2 hours to fit...!!!! I need to go and get a job there..! Maybe all their techicians are blind and only have one arm.
I've done several (when I was making cables) sitting in the persons car in the rain. Even with the doors closed it didn't take more than 20 min..!
ToreB, I don't know what the OEM cable consists of but a simple GLI is just a 1:1 transformer on each channel. Small signal transformers from the communications industry is what I used.
United Nations View GadgetGav's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 26th, 2004, 09:48 PM   #7 (permalink)
KID
KID's Avatar
Local Time: 09:23 PM
Japan DIY AUX input
Hi.
thank you guys for information about this.
I just installed DIY AUX input and isolator.
I made ground loop isolator by myself.
The transformer' s impedance is 2000 Ohm for both.
here is the detail
http://www.fbody.jp/mini/
ID:	29148  Click image for larger version
ID:	29149  Click image for larger version
Japan View KID's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jan 27th, 2004, 07:45 AM   #8 (permalink)
ToreB
ToreB's Avatar
KID, this is very good. Congratulations with a very resourceful web site.
Best regards.
Tore
Old Jan 27th, 2004, 08:28 AM   #9 (permalink)
Neeshil
Local Time: 10:23 PM
Cool! Glad my site helped someone (Of course my guide that I typed up was only possible because of everyone at Mini2)
Australia View Neeshil's Pure Silver & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Jan 28th, 2004, 08:25 AM   #10 (permalink)
Wylex
Official Min aux kit???
Hey i've heard some talk above of there being an official mini aux kit? Where did you get it, are they also available in europe as it seems the people above have talked in $$, and does the actual delaer have to install it or is it DIY kit they sell?
Wylex
Netherlands View Wylex's Solid Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jan 28th, 2004, 12:48 PM   #11 (permalink)
azimmerm
azimmerm's Avatar
Local Time: 07:23 AM
Wylex
check with your dealer. they should have it.
Old Jan 28th, 2004, 01:52 PM   #12 (permalink)
Bugged
Just along for the ride
Bugged's Avatar
Send a message via AIM to Bugged Send a message via MSN to Bugged
The official MINI kit should be available from your dealer for $35 to $40. It CAN be installed easily yourself in less than 30 minutes. However if you have a model year 2002 MINI, it will not work.
United States View Bugged's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 31st, 2004, 12:37 AM   #13 (permalink)
KID
KID's Avatar
Japan Thank you
Thank you ToreB.
I am interested in your Gallery.
Thank you Neeshil.
Your guide has been a really big help.
Especially, using PC parts idea is wounderful, great, impresive.
Tomtom 910 + 2004 Aux Input vicious Interior & Ice 0 May 3rd, 2007 06:04 AM
Mini aux input cable - mp3 input to wave, boost or HK Mini-Trainer For Sale 3 Aug 7th, 2005 07:02 PM
Does 2005 HK stereo offer Aux _mode_ or just Aux input Mini4Cathy Interior & Ice 2 Jul 16th, 2005 03:30 PM
DIY Aux Input for iPod --- connector Pin Part #'s anyone? jay.snyder Interior & Ice 4 May 3rd, 2004 11:15 PM
2004 Aux input and HK Stereo Issues GAMini Interior & Ice 7 Nov 23rd, 2003 03:02 AM
