GizzmoUSA
Old Feb 5th, 2004, 02:49 AM   #1
aiois
Local Time: 05:43 PM
Mounting a Sirius Antenna with a Sunroof
I just received my MINI last week and have a Kenwood Sirius satellite system I would like to install. However, the magnetized antenna I have will not attach to the roof. I am guessing this has something to do with my sunroof.
Would it be possible to mount the antenna on the bottom of the cargo area cover? Or should I just Velcro the antenna to the roof? Has anyone had any success with this, or any other, method to mount the antenna?
Any help is appreciated. Thanks!
Old Feb 5th, 2004, 09:40 AM   #2 (permalink)
Cape Cod MINI
Exposing the Beast
Cape Cod MINI's Avatar
Local Time: 07:43 PM
Mine is mounted just forward of the sunroof.
Wiring is concealed under the wind shield molding.
It's black so it blends nicely.
Old Feb 11th, 2004, 07:29 AM   #3 (permalink)
pkrehbiel
MINI2 Sponsor
pkrehbiel's Avatar
DIY Sirius Antenna
Mine is installed centered on top of the dash, at the very front edge of the windscreen.
2002 JCW MINI Cooper S
Polk MOMO 6.5" Front Speaker
Polk MOMO 6x9" Rear Speakers
MTX Thunder 404 4x100 Watt Amplifier
Kenwood Here2Anywhere Sirius Satellite Radio
Rockford-Fosgate Omnifi DMP1 MP3 Hard Disk Changer
Blitzsafe DMX v.1 Auxiliary Input Adapter
PIE MPSS-2 2-Channel Source Switcher
The DMX unit plugs into the CD Changer input, the MPSS-2 plugs into the DMX, and there is a toggle switch in the open center switch console position that switches between the Sirius Satellite input and the Omnifi mp3 input. The Omnifi hard disk source unit sits in the glove box and the Sirius antenna is mounted on the center of the dash in front of the UV sensor. I wanted to go the factory route on the Sirius but the MINI dealerships were all so unhelpful that I finally gave up. I'm glad I did, as now my problem is way too many choices! I was stunned at the low quality of the factory speakers.
United States Male View pkrehbiel's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 11th, 2004, 12:04 PM   #4 (permalink)
aiois
Since I am already using the AUX input for my iPod, I can purchase a BlitzSafe adaptor to access the CD input directly? Also, are you using the included cradle to mount your Here2Anywhere unit? Or are you mounting it to the bottom of your MP3 player?
Thanks much!
Old Feb 12th, 2004, 12:46 AM   #5 (permalink)
pkrehbiel
MINI2 Sponsor
pkrehbiel's Avatar
Yes, that is how the Blitzsafe input works. I hard mounted the Here2Anywhere unit in it's cradle under the mp3 changer. You need to do this because the receiver unit is not meant to connect directly to the antenna or the RCA outputs, it needs the cradle to do this. Good luck.
Old Apr 28th, 2004, 01:04 PM   #6 (permalink)
storer
Local Time: 11:43 PM
[quote=pkrehbiel]Mine is installed centered on top of the dash, at the very front edge of the windscreen.
Seems like a great idea, answers my question of, "How ugly will the antenna look mounted off-center on the roof?" Not to mention, no hoodlums can steel it that way.
Do you have any problems with the reception with the antenna in that location? Also, how did you mount the antenna? Some sort of adhesive backing?
-Chris
03IB/W MCS, the most rockin' vehicle on the road!
Old Apr 28th, 2004, 10:07 PM   #7 (permalink)
pkrehbiel
MINI2 Sponsor
pkrehbiel's Avatar
Chris,
Reception is great, no problems with the dash mount antenna. It is mounted with double sided tape, so you can remove it to remove the dash.
Best of luck,
Pete
UHF Antenna Mounting MickyD Exterior 1 Mar 29th, 2006 12:01 AM
Help with Sirius Antenna on convertible acaciolo Interior & Ice 4 Apr 25th, 2005 02:00 PM
Sirius Antenna jbian MINI Convertible 3 Feb 25th, 2005 02:28 AM
Sirius Antenna jbian Interior & Ice 0 Feb 24th, 2005 06:23 PM
Sirius mounting options? sprocket Interior & Ice 1 Oct 20th, 2004 03:10 AM
