Old May 1st, 2004, 09:30 PM   #1
flatsix02
Hulk.
flatsix02's Avatar
Local Time: 07:51 PM
Send a message via AIM to flatsix02
Speedo Ring Removal Help?
A good friend of mine paints cars for a dealership nearby and i saw that a guy on mini2 had his speedo ring, the tach ring and the rings next to the speedo painted body color. I want to do this really badly and i was told that i just need to have the rings off and i can have them painted.
Question is, how do i remove those? Do i just pull up on them really hard and hope they come off, do i twist them or what?
Thanks,
Scott
United States View flatsix02's British Racing Green & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 2nd, 2004, 02:44 PM   #2 (permalink)
flatsix02
Hulk.
flatsix02's Avatar
Old May 2nd, 2004, 03:15 PM   #3 (permalink)
devilsushi2000
In Barbados until 1st Sep
devilsushi2000's Avatar
Local Time: 12:51 AM
Send a message via MSN to devilsushi2000
twist them a little and then they should just come off. Some twist off easier than others
Dale
England   Reply With Quote
Old May 2nd, 2004, 03:20 PM   #4 (permalink)
flatsix02
Hulk.
flatsix02's Avatar
Old May 2nd, 2004, 03:20 PM   #5 (permalink)
GJR
GJR's Avatar
Local Time: 08:51 PM
I'm wondering about this as well, because I want to retrofit the new Cabrio factory chrome interior pieces to my coupe.
United States View GJR's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 16th, 2004, 01:20 PM   #6 (permalink)
Paul
Trained Monkey
Paul's Avatar
Local Time: 01:51 AM
Can we confirm that the speedo ring "twists off" please. I might "have" to do this soon too, and I tried it, and my speedo ring wouldn't budge?!
Which way should I be twisting?
Any top tips?
Old May 16th, 2004, 01:22 PM   #7 (permalink)
Rich_IX
Official Pimp of Mini2
Rich_IX's Avatar
Send a message via ICQ to Rich_IX Send a message via MSN to Rich_IX
Crowbar
Id rather have Sat Nav Anyday
United Kingdom Male View Rich_IX's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 16th, 2004, 01:24 PM   #8 (permalink)
Paul
Trained Monkey
Paul's Avatar
Yeas, thanks Rich. I don't want to destroy (or damage) anything in the process though.
Anyone with any sensible ideas or experience want to chime in, feel free.
Old May 16th, 2004, 02:39 PM   #9 (permalink)
Windshadow
Windshadow's Avatar
putty knife wraped with tape and wiggled in the crack? I was wondering if the 05 chrome line will retrofit to my 04 sat nav dials?
S BRG/W Randolph 3 PAC NAV
Mid Coast Maine, U.S.A.
United States Male View Windshadow's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 16th, 2004, 02:43 PM   #10 (permalink)
Paul
Trained Monkey
Paul's Avatar
I've thought about using strong tape stuck to the dial then pulling that from two directions to twist the ring?
Not sure if the stuff will retrofit, no reason why not, apart from the rear cup holder ring (as that's now bigger). However, if MINI will offer it as a retro fit part is another matter.
Old May 16th, 2004, 09:18 PM   #11 (permalink)
snoopy
Local Time: 10:51 AM
It has been a while, but I am sure their is no twisting only pulling.
Old May 16th, 2004, 09:20 PM   #12 (permalink)
Paul
Trained Monkey
Paul's Avatar
But now it's been said to twist, I'd be scared to break something pulling it!
Can anyone else say for 100% certain? I've twisted and pulled everything else off, but the speedo ring I cant twist off, and I've been afraid to pull.
I don't even have anything to replace them with yet, but I'd like to know all the same?!
Old May 16th, 2004, 09:37 PM   #13 (permalink)
snoopy
I though I only pulled have a look at photo. Now I did not try and take it any more apart than this.
Old May 16th, 2004, 09:40 PM   #14 (permalink)
Paul
Trained Monkey
Paul's Avatar
Yikes!!
It's just the ring alone I want off, I've managed to get the two blower rings off, but not the speedo.
I know others have done this to paint their trim.
Old May 17th, 2004, 08:17 PM   #15 (permalink)
Paul
Trained Monkey
Paul's Avatar
OK, I've tried pulling, and I've tried twising. My fingertips are sore, and the speedo ring is still in place.
If I knew for sure if we were supposed to twist or pull I might be more confident to pull or twist harder?!
Anyone want to help us out here?
Thanks again!
Paul
Old May 18th, 2004, 05:46 AM   #16 (permalink)
wmd
wmd's Avatar
Local Time: 06:51 PM
Unhappy Glued in?
The only way I see to get the Speedo ring off is to remove the entire fascia section like snoopy did. There are 3 screws to remove (2-top and 1-btm) and a swift yank needed to break 4 spring clips loose. The only thing you need to watch is both sides of the Speedo section, underlap the ones of either side. So you have to watch when reinstalling to get the seam on each side under the adjacent section.
On the back side of the Speedo ring there are six clips spread evenly around the perimeter. But the kicker is that four of them have been hot-melt glued. The good news is the glue is very soft and looks like it would be easy to remove. In addition there is a single forked spring clip at the bottom that needs to be squeezed together to disengage. No way to remove that one from the front, as far as I can tell.
Old May 18th, 2004, 07:58 AM   #17 (permalink)
AidenL
Nice TTs.........
AidenL's Avatar
Send a message via MSN to AidenL
Great info wmd, I'm sure Paul will be pleased.............
No wonder it wouldn't twist off or pull off then........
Global Moderator
Ireland Male View AidenL's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 18th, 2004, 09:56 AM   #18 (permalink)
Paul
Trained Monkey
Paul's Avatar
If only I'd have known BEFORE I tortured my poor old finger tips!
Thanks WMD.
Old May 18th, 2004, 10:11 AM   #19 (permalink)
AidenL
Nice TTs.........
AidenL's Avatar
Thanks WMD.
NOT a simple install then, for the speedo ring at least............
Global Moderator
Old May 18th, 2004, 11:36 AM   #20 (permalink)
Paul
Trained Monkey
Paul's Avatar
Right. Got the little blighter off! (Why I've done this with nothing to put in it's place is beyond me?!).
Anyway, I'll post pics later. IN THEORY I think you could just pull it out, once I'd pulled the whole thing apart, I didn't have to do anywork really from behind the ring, I managed to just pull it off, however I think the long way around is safer, and it only took about 15 mins to do.
Pics and guidelines to come for anyone else wanting to do this!
what indicators mean on the speedo ring! gamze General Discussion 7 Oct 6th, 2006 12:16 PM
Speedometer Ring Removal SCMCS Interior & Ice 7 Feb 20th, 2006 02:23 AM
Metal ring removal for airbox hose?? CYNMINI Engine & Drivetrain Tuning 4 Jun 7th, 2005 09:23 PM
Chrome speedo ring help please? Scylla Interior & Ice 0 Oct 26th, 2004 04:57 PM
Chrom-Design Speedo Ring: Gorgeous but...? 2nd Mini Interior & Ice 6 May 7th, 2003 05:39 PM
