| MINI2 Senior Join Date: Jun 2004 Location: Stanford, CA Local Time: 11:46 AM
Offline | Aux input - worth it? any problems? I have an iPod that I used to have hardwired into my old car. I definitely want some sort of decent-quality connection for it, and anything else I may want to plug in at any given time. Also, I will have nav on my new Mini so the BMW/iPod deal is presumably not an option. Is the aux input worth it? Any downsides? I'm inclined to go for it but was wondering if there are any drawbacks. Thanks. -mike |
| brown is back Join Date: Sep 2002 Location: Burlington, VT Local Time: 02:46 PM
Offline | I believe that's where the instructions with the parts say to install the "port". But, if you're even slightly inclined, and own some torx bits, you can just buy the part and say "I'll install it myself" and put it wherever you want. I did that, and just ran the cable out the bottom of the little plastic door thingy at the base of the dash legs. Alternately, if your dealership is nice, you can probably tell them where you would like the heaphone jack like part to go... |
Offline | Hmm I'm tempted to do that but I'm not entirely sure of the configuration of the 05 interior in terms of that sort of thing... It would definitely be preferable to have it elsewhere. -mike |
| | #7 (permalink) |
| Sitting on a park bench.. Join Date: Aug 2003 Location: Bahstun, MA Local Time: 02:46 PM
Offline | Mine's NOT in the glovebox I had my dealer install it in the pillar, and I much prefer it there...see here for some pics http://www.mini2.com/gallery/persona...ery_11982.html down towards the bottom. Don't forget the Belkin car adapter which has a powered line out (don't use the controller output as it attenuates the signal for headphones) and don't use iTrip! You can also see I place mine in a Panavise 2000 model 703 mount, really for a mobile phone but it works great for the iPod...up high, I can see it easily (and safely). |
| | #8 (permalink) |
Posts: n/a
| I installed mine myself (50 quid seemed a bit excessive i thought though) 1 week after i got the car. It's not hard to fit if you don't mind getting your hands a little dirty - I'm almost certain it's possible to install it without taking the centre console (like i did) to bits just by removing the little plastic panel under the toggles. There seems to be a load of space behind and you should be able to line up the connector you get. I just drilled a hole in that panel and put the port there. With my belkin tunedok and the belkin car kit it's really tidy. Just have a 3" long jack to jack to connect the aux to the belkin adaptor and you're laughing. One thing though is if you do attempt it don't over tighten the radio back in (if boost anyway) - it's made of plastic and is easy to break :/ I can post some pics if you like. |
http://www.mini2.com/forum/
| | #10 (permalink) |
| MINI2 Senior Join Date: Dec 2002 Location: Raleigh, NC Local Time: 02:46 PM
Offline | Installed the AUX port myself for my iPod and it works a treat. Perfect sound quality and the volume controls work through the MFSW. Highly recommended - haven't used my radio since it was installed 4 months ago. |
| | #11 (permalink) |
| The Silverado Join Date: Apr 2003 Location: Sydney, Australia Local Time: 04:46 AM
Offline | do it! i cant do the AUX because my mini is a july 2002 build and the HU doesn't have the AUX port. I managed to use a blitzsafe adapter which plugs directly in to the CD Changer wires in the boot, i then ran an RCA caple to the front of the car and my pod plugs into that same deal really.. no drawbacks 100% quality sound. benno |
| | #13 (permalink) |
| MINI2 Regular Join Date: Jan 2003 Local Time: 08:46 PM
Offline | do it! it's very easy and requires no drilling, just one screw to loosen, so you can do it yourself. The DIY FAQ has excellent pictures. I've got mine in the cupholder which allows easier access. |
| | #14 (permalink) |
| MINI2 Newbie Join Date: Jul 2004 Local Time: 02:46 PM
Offline | compatible with hk and sirius? Can someone verify that the AUX input can be installed if both the Harmon-Kardon speaker system and Sirius satellite receiver are present? I'm picking up my new Mini which has these options tomorrow, and want to get my iPod hooked up as soon as possible. Thx, Jeff |
| | #17 (permalink) |
| Man in the know! | there is an official aux input available, that plugs into the back of the HU. also pretty soon there will be an adaptor that allows you to control the ipod through the steering wheel. check out www.ipodyourbmw.com this is currently only available in North America, however MINI GB have these items in for test fit at the moment. I have heard that they will not work if you have a CD changer, or Changer prep, as they use that connection point for the Ipod port. |
| | #18 (permalink) |
| MINI2 Regular Join Date: Dec 2003 Location: Peterborough Local Time: 07:46 PM
Offline | guys guys guys, ive got an ipod and use an iTrip. Buy one on ebay for £30. It broadcasts an FM frequency to your stereo and you just tune your stereo into it. Its so easy and sound quality is fine.Its cheap, easy and can be used in your house too, any stereo with a radio can play you ipod music.!! Any more questions pm me |
| | #19 (permalink) |
| can i go home yet | it was the official one which wasnt working - could it be to do with my head unit although the dealer claims to have changed it for another one to check Really don't understand why its doesnt work given lots of people here have managed to get it to work |
| Problems After Installing Aux Input | brittsroyal | Faults & Fixes | 6 | Feb 11th, 2006 07:28 PM |
| Mini aux input cable - mp3 input to wave, boost or HK | Mini-Trainer | For Sale | 3 | Aug 7th, 2005 07:02 PM |
| Does 2005 HK stereo offer Aux _mode_ or just Aux input | Mini4Cathy | Interior & Ice | 2 | Jul 16th, 2005 03:30 PM |
| Aux. Gauges vs. Aux. Audio Input | Roberto | Interior & Ice | 11 | Mar 24th, 2004 04:02 PM |
| Aux Input problems - all hooked up but not showing up! | jebjeb | Interior & Ice | 9 | Jul 26th, 2003 08:08 AM |
