GizzmoUSA
Old Jul 11th, 2004, 07:44 PM   #1
MiniBeefy
MiniBeefy's Avatar
Local Time: 12:06 AM
Send a message via MSN to MiniBeefy
England JCW Seat Fitting - Air Bag connections ?
Picked my seats up from Tony @ CoolNew on Saturday and went to fit them today ...
Firstly I need to get the correct tool for the job, while I could get the old seats out of the car no problem, I then found that I need a very short angled key in order to get the old seats of the old runners ... anyway will get one tomorrow and that should all be OK.
... anyway, put the seat back in and the forget the reconnect the airbag sensors at which point I noticed the light on the dash was on ! Ignition off and plugged connections back in. Ignition on ... A/B light stays on.
Questions ;
Because it picked up a problem with the A/B once will the light stay on until the dealer checks/resets the computer ? (just a thought)
Once the JCW seats are in is it a dealer job to disable the sensors so that the airbag light is not one 100% of the time or is there anyway of doing this myself ?
Many thanks
2004 Dark Silver MCS JCW Aero kit, Chilli Pack, 18" BK299s, JCW Seats, Dension head unit, 2 x Genesis Profile 2 Amps, Genesis 6"x9" Subs, Focal K2 Power 165KP
2000 Lotus 340R
Old Jul 11th, 2004, 08:00 PM   #2 (permalink)
LMB
Toon Toon..
LMB's Avatar
<div><a href=
Pics?
Global Moderator
England Male View LMB's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 11th, 2004, 08:16 PM   #3 (permalink)
ASTON
A mini is a way of life.
ASTON's Avatar
Send a message via MSN to ASTON
if you disconnect the battery for 3 hours,then reconnect the system will reset its self.
Wales Male View ASTON's Pepper White & Black 2nd Gen MINI Cooper Diesel Profile   Reply With Quote
Old Jul 11th, 2004, 08:20 PM   #4 (permalink)
MiniBeefy
MiniBeefy's Avatar
England
Quote: Originally Posted by LMB
Pics?
Seats not in but will post them once they are, hopefully tomorrow
Many thanks ... off to disconnect now.
2000 Lotus 340R
Old Jul 11th, 2004, 08:25 PM   #5 (permalink)
ASTON
ASTON's Avatar
Wales
thats what my local dealer said to do. if that dont work i will go there and fill him in
Old Jul 11th, 2004, 09:25 PM   #6 (permalink)
Damo
MINI2fosi
Damo's Avatar
Send a message via MSN to Damo
Plugged back in? Plugged back in to what?
United Kingdom Male View Damo's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 11th, 2004, 10:01 PM   #7 (permalink)
MiniBeefy
MiniBeefy's Avatar
On the bottom on the original seats there are 2 plugs for the airbags sensors in the seat, these don't exist on the JCW seats
2000 Lotus 340R
Old Jul 11th, 2004, 10:17 PM   #8 (permalink)
Damo
MINI2fosi
Damo's Avatar
Ahhhhhhh I understand now, as you put the original seats back in. Any Chance you could let me know what tool is needed for those runners, as me and bengascoyne are fitted ours with each others help.
I think the wires have to be plugged with a bridge connector and then re set with the computer, so the car thinks it has airbags or summat.
Old Jul 11th, 2004, 10:24 PM   #9 (permalink)
MiniBeefy
MiniBeefy's Avatar
The star driver (probably not the correct term) that is used to unbolt the seat from the car is also required to unbolt the seat from the runners (which are re-used with the JCW seats), however there is very little clearance and my socket start driver would fit due the lack of clearace between the top of the bold head and the bottom of the seat. A normal alum key style one probably would.
If I get the tool tomorrow I'll email you a picture
2000 Lotus 340R
Old Jul 11th, 2004, 10:26 PM   #10 (permalink)
Damo
MINI2fosi
Damo's Avatar
Cool, think my socket set should be fine. Tried raising the original seat first *L* Or do you mean for when you re-fit the works seats?
Old Jul 11th, 2004, 10:37 PM   #11 (permalink)
MiniBeefy
MiniBeefy's Avatar
It was when I was trying to take the original seats off the runner rails, as the JCW seat is fitted to the runners which are in turn re fitted to the car.
2000 Lotus 340R
Old Jul 11th, 2004, 10:50 PM   #12 (permalink)
Damo
MINI2fosi
Damo's Avatar
Cool, thanks for the info.
Old Jul 12th, 2004, 02:28 PM   #13 (permalink)
MiniBeefy
MiniBeefy's Avatar
England
OK, we're there ... well nearly ...
Firstly I managed to get to correct tool from Halfords this morning, a T40 star drive key, as you will see from the first picture there simply isn't enough space to get a socket drive in.
It quiet a fiddly process of fitting the seats, first one took me approx 2 1/2 hours, second one took about an hour, as I had figured out how to get the seat belt wiring out and the recoil assembly disconnected from the standard rails.
Unfortuneatly I have received two right hand seat belt attachment brackets, which means until its exchanged I can't take passengers in the front as there is no seat belt. Stephen at Coolnew is onto this one with BMW.
As for the airbag light ... well that has to be done by a dealer and re-prog the computer not to look for airbags in the seat. This was confirmed by Stephen at CoolNew today and this is what they had to do.
Anyway seats are in OK, as pictures show and feel excellant although I haven't taken the car for a drive yet.
Sorry for the poor quality pictures they're mobile ones as the wifes gone out with the digital
ID:	43770  Click image for larger version
ID:	43771  Click image for larger version
2000 Lotus 340R
Old Jul 12th, 2004, 10:59 PM   #14 (permalink)
Damo
MINI2fosi
Damo's Avatar
Nice! Preety sure My socket set is smaller than that. The "Star" key is ony about 5mm out of the socket so shoudl fit wil have a look tomorrow. My seats are going to take the longest due to what i want (Half Leather with the cloth in red)
Old Jul 13th, 2004, 07:08 AM   #15 (permalink)
MiniBeefy
MiniBeefy's Avatar
First impressions after this morning's drive to work ;
Excellant ... buckets (boooo) of lateral support and I found myself chucking the car at corners hard and could feel what was happening beneath me much better.
Seats don't touch the head lining as previously posted, there is loads of clearance.
They do reduce rear leg room somewhat.
On the subject of removal of the old seats ... there really no problem at all and will come out of either door very easily.
2000 Lotus 340R
Old Jul 13th, 2004, 10:39 AM   #16 (permalink)
bengascoyne
bengascoyne's Avatar
hi beefy,
So a good thumbs up then?? Can I just ask, how low down are yours?? Are the seats quite low, like the originals when they're at their lowest?
Cheers for the fitting pointers as well, am sure Me n Damo will make use of em. Oh and could you please let us know how much BMW charge you the light and re-prog!
Ta mate,
Ben.
VW MK4 GOLF R32 (now left ) MCS NOW ARRIVED
England Male View bengascoyne's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 13th, 2004, 11:36 AM   #17 (permalink)
Davislove3rd
Riding on JCW power!
Davislove3rd's Avatar
how did you know the correct torque for the bolts? i think this is important am I right?
United Kingdom View Davislove3rd's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 13th, 2004, 04:19 PM   #18 (permalink)
MiniBeefy
MiniBeefy's Avatar
Yeah really throwing the car hard at corners now. I couldn't really say how high/low they are in comparison to the standards as they feel so totally different. If anything I say the feel higher.
Cooper Croydon as scheduled to do the light issue on Monday morning (19th July) will post the costs up then, but its a 'while you wait' job. 1st dealer who supplied the car didn't know what I was talking about so I went elsewhere.
Good point, I've just done them the non-scientific way, they were very tight, so I've done them to what I feel is appox the same. If anyone has the correct torque settings for this I'll check mine.
2000 Lotus 340R
Baby Seat and Front Air Bag Deactivation justineallen MINIs, Children & Parents 12 Dec 31st, 2007 05:30 PM
JCW seat fitting- tilt connector fitment? eddycooper John Cooper Works & GP 1 Jun 20th, 2007 09:03 AM
fitting a jcw air intake HELP!!! checkmatechris MINI Cooper S 6 Apr 26th, 2007 10:21 PM
Air Bag Mandi Maintenance & MINI Care 3 Sep 29th, 2003 07:22 PM
Air bag light on stevearcher Faults & Fixes 10 Oct 8th, 2002 01:21 PM
