GizzmoUSA
Old Aug 28th, 2004, 02:06 PM   #1
snid
brown is back
snid's Avatar
Local Time: 09:24 PM
Tips for cutting the boot floor
I'm looking for tips for cutting the foam backed carpet on the lift up boot floor that covers to tool kit on a Cooper (or battery on an S). I had a JL Audio Stealthbox subwoofer installed, and that blocks access to the tool kit / spare. It's not too hard to remove the Stealthbox (remove the rear seat back, then unbolt the bracket on the Stealthbox), but it would be much easier to not have to do that.
I realize that rule number one is "measure twice, cut once". But, what about cutting itself? Just grab a carpet style blade and go at it? Anything special to keep the foam backing from getting trashed?
jtross | snid | jason - bloggage (including videos)
United States Visit my Blog at the Motorcade Male View snid's Velvet Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Aug 28th, 2004, 04:14 PM   #2 (permalink)
obehave
Mini Mod
obehave's Avatar
You want to compress the foam as much as you can and use a very sharp blade.
Slide a piece of masonite or something similar under the carpet. Use a good metal straight edge so you can press down nice and hard.
The foam should be fine if the blade is sharp enough.
Old Aug 28th, 2004, 10:12 PM   #3 (permalink)
soopacoopa
soopacoopa's Avatar
Local Time: 03:24 AM
I've had to do this job myself. I tried with a blade but the hardboard was too tough for me. I ended up drilling 4x 10mm holes (did this in stages: 3mm, 6mm, 8mm then 10mm) in the corners of the rectangular cut-out I wanted in the carpet, and then I used a power jigsaw to 'join-the-dots'. I did all of the work with fairly low cutting speeds, and with the assistance of fixtured blocks to guide the saw and keep my cuts straight. I ended up with nice clean edges on the carpet and the foam, but I decided to use some black plastic extrusion to finish the raw edges.
Hope this helps,
Richard
United Kingdom View soopacoopa's Dark Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
One D Cutting Out!! ONED MINI One Diesel 19 Apr 29th, 2008 09:43 PM
installing rubber floor Mini floor mats gfoye Maintenance & MINI Care 3 May 1st, 2007 07:36 AM
H/K not cutting it msenkbeil Interior & Ice 1 Apr 22nd, 2003 07:32 AM
False Boot Floor bennyboy Interior & Ice 2 Sep 25th, 2002 05:16 PM
Engine Cutting Out!!!!! Smiffy42 Faults & Fixes 6 Apr 9th, 2002 07:53 AM
