Adam's Polishes
Tags: , , , , , , , , , ,
Old Apr 28th, 2005, 09:36 PM   #1
Restyle
Damned
Restyle's Avatar
Local Time: 07:46 PM
New A Pillar - Ipaq - Ipod - Mobile Mounting
Thought I`d share my new Ipaq sat-nav mount system with you all.
Dont know if anyone has already done anything similar, but by mounting a Ball-Jointed interior Rear View Mirror onto the Drivers A-Pillar, this offers tremendous potential for holding all those Gadgets that normally either drop off their window suction mounts, or are out of the field of view when you need them most.
I`d made something similar a while ago with the MINIPOST , but found that they must have altered the angle of the Dash on the 05 models as the Ipaq was at the wrong angle & snagged on the Pillar.
The Ball Jointed mount was fixed in place via captive nuts welded onto a plate behind the Pillar Housing, (which incidentally is just £11 from BMW if you dont want to damage your original), But if the device you plan to mount is light enough & you dont fancy doing any drilling, then a mirror mount can be stuck in place via good quality double sided tape.
I was thinking about trawling the scrapyards for an appropiate mirror but got this brand new chrome one seen here from Stafford Vehicle Components for a not unreasonable £15.
A piece of Extra Strong Velcro strip was then stuck onto the Mirror Surface ready to attatch to pre-Velcro`d Devices
Let me know what you think .. or of any new uses or possible improvments to it
Name:	Drill Holes in Plastic Pillar Housing.jpg
ID:	82578  Click image for larger version
Name:	Chrome Spigot Bolted onto A-Pillar.jpg
ID:	82579  Click image for larger version
Name:	Front View 001.jpg
ID:	82580  Click image for larger version
ID:	82581  Click image for larger version
Name:	On the Road.jpg
In da Wud
Old Apr 29th, 2005, 11:38 AM   #2 (permalink)
Aqualung
Sitting on a park bench..
Aqualung's Avatar
Local Time: 02:46 PM
Pretty cool setup...does it interfere with you field of vision when you look to your side mirror?
United States View Aqualung's Indi Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 29th, 2005, 01:10 PM   #3 (permalink)
Restyle
Damned
Restyle's Avatar
Not at all, as its within the top-dash area and not protruding anywhere near the side window.
I`m actually doing the 1st Mod to it today, by disposing of the actual mirror, & replacing it with a much smaller, (& neater), piece of 4mm ally onto which will act as the new Holding Pad
In da Wud
Old Apr 29th, 2005, 01:33 PM   #4 (permalink)
jwardell
jwardell's Avatar
Send a message via AIM to jwardell Send a message via Skype™ to jwardell
Interesting idea. Isn't the A-pillar destroyed when removed though...did you just mount it to a new one?
Also if the air bag goes off you will have your PDA and that mirror propelled at the speed of sound...
United States Male View jwardell's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 29th, 2005, 02:02 PM   #5 (permalink)
Restyle
Damned
Restyle's Avatar
I bought a new A-Pillar cover, but in the event used the original - It can easily be reverted back to normal in around 10 minutes.
After the rubber door seal from around it is pulled back, the cover is removed by simply pulling it from its top edge.
There are No airbags mounted behind the cover
..aren`t the optional Head Air Bags mounted in the Roof ??
The Steering wheel airbag remains totally unaffected by this installation.
Name:	Bare A-Pillar with cover removed.jpg
ID:	82611  Click image for larger version
Name:	Sandwich plate with captive Nuts.jpg
ID:	82612  Click image for larger version
Name:	Removing Cover.jpg
In da Wud
Old Apr 29th, 2005, 05:44 PM   #6 (permalink)
jwardell
jwardell's Avatar
Ahh..I forgot you guys had optional airbags. All MINIs have them here. And yes, the side curtain airbags start at the bottom of the A-pillar and go all the way up to the back of the car. Maybe it's the airbag a-pillar cover that is not reusable and there is a different part if you don't have curtain airbags. That would make sense since they wouldn't have to make space for the bags, and don't need to brake away when the bag fires.
And in that case...good idea
Old Apr 29th, 2005, 07:12 PM   #7 (permalink)
tradiuz
Local Time: 01:46 PM
The airbag is not actually in the pillar, its in the headliner,in the seat, above the glovebox, and in the steering wheel. The reason it says airbag on the A-Pillar is due to the wiring running through it to warn paramedics using the jaws of life on the A-Pillar that it might deploy a possibly-fatal airbag.
United States View tradiuz's Hyper Blue & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Apr 29th, 2005, 09:00 PM   #8 (permalink)
Restyle
Damned
Restyle's Avatar
So is it mandatory for ALL new cars over there to have these extra Roof airbags??
That makes Good sense
As mentioned earlier, I was working on its redesign today to make it neater & more aesthetic.
The original Mirror Glass to which the Velcro was stuck, has now been replaced with a smaller piece of 4mm aluminium plate. The total area of attatchment remaining the same.
Name:	Redesign -Side View 001-.jpg
ID:	82664  Click image for larger version
Name:	Redesign -Side View 003-.jpg
ID:	82665  Click image for larger version
Name:	Redesign -Front View 004-.jpg
In da Wud
Old Apr 29th, 2005, 11:19 PM   #9 (permalink)
Baker
Being normal is not fun!
Baker's Avatar
Local Time: 04:46 AM
I love the idea, my only problem with it is that it looks a bit out of place. I'm wondering if I can modify your idea any to achieve my own system
Kev
Australia Male View Baker's Dark Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 24th, 2005, 08:57 PM   #10 (permalink)
Restyle
Damned
Restyle's Avatar
Another SatNav device finds its way onto the Mount
Name:	E200 On the Road 005.jpg
ID:	86456  Click image for larger version
Name:	Velcro on outer Case.jpg
ID:	86457  Click image for larger version
Name:	On Mount 001.jpg
ID:	86458  Click image for larger version
Name:	On Mount 002.jpg
In da Wud
Old May 24th, 2005, 09:03 PM   #11 (permalink)
AidenL
Nice TTs.........
AidenL's Avatar
Send a message via MSN to AidenL
Very inventive...........
Does it explode?
Global Moderator
Ireland Male View AidenL's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 24th, 2005, 10:23 PM   #12 (permalink)
Restyle
Damned
Restyle's Avatar
Quote: Originally Posted by Aiden
...Does it explode?
You`ll have to wait for my 2000th Post to see the latest Pyro Adventures
(Not long to go now)
In da Wud
Old May 26th, 2005, 03:56 AM   #13 (permalink)
SugarBelly
SugarBelly's Avatar
Lightbulb Looks smart!
Very fine work, Restyle.
I faintly remember someone here building a post, inserted into the dash vent for a similar viewing position. Your invention seems an easier DIY build.
Q : Any chance you can take a shot demonstrating viewing text the size an ipod employs?
I don't mean to annoy.
Just got an ipod & wondering the normal things, - which adaptor, if attempting to focus on the screen is too distractiing while motoring, etc.
Either way, please offer build & mount hints as possible. Thanks in advance!
Old May 26th, 2005, 06:50 AM   #14 (permalink)
Restyle
Damned
Restyle's Avatar
That was probably one of mine as well (Link to it in 1st Post)
I havnt got an Ipod so got no idea of the size of its text, but I can easily read the Street name text on the Smaller mobile satnav so it cant be too different.
In da Wud
Old May 30th, 2005, 02:33 AM   #15 (permalink)
SugarBelly
SugarBelly's Avatar
Thanks for the reply!
Fab work, Restyle.
Still like your origial MINI-Post, too.
Old Jan 2nd, 2007, 10:56 PM   #16 (permalink)
Restyle
Damned
Restyle's Avatar
Recently tried it out with a TomTom 510
Just had to angle the ball mount a little ... & add a pad of Velcro to the underside of the 510
In da Wud
Mounting an Ipaq Suggestions geist Interior & Ice 24 Aug 24th, 2005 10:26 PM
the best ipod mounting ever averyocooper Interior & Ice 19 Sep 7th, 2004 12:08 PM
Is there an Ipaq(PDA) mounting kit???? mini_s_cab Interior & Ice 5 Aug 5th, 2004 11:08 PM
IPOD Mounting and needs Rabboeni Interior & Ice 22 Mar 5th, 2004 07:28 PM
Mounting a Nokia mobile phone rich Interior & Ice 13 Oct 28th, 2002 07:24 AM
