| MINI2 Newbie Join Date: Dec 2003 Local Time: 09:43 AM
Offline | Where is the Speed Pluse Wire on the Convertible? Hi, I've just installed the Pioneer AVIC-X1 in my Mini Cooper S Convertible (2005) -and the last thing I need to do is connect it to the speed pulse wire. However there is no sign of it !-it was located in the drivers sill on the Hatchback (2004) Does anyone know where is the Speed Pulse wire on the Convertible?? Thanks in advance! |
| MINI2 Master | I have a Kenwood 925DVD and had the same problem when installing it in my Convertible Cooper S, after many hours of looking around upside down with my head under the dash, i found mine!!! If you look under the dash on the drivers side, you will see a large loom running down towards the sill, its in the middle of that lot!!!! If you carefully cut away some of the felt tape holding the loom together and seperate the wires you will find a small Green/Yellow wire (approx 0.5mm CSA) in the middle of it all. I just scratched away some of the insulation with a stanley knife to connect mine and then re-covered it again with insulation tape. Hope this helps you, any problems let us know. ![]() |
| | #7 (permalink) |
| Thinking Minis | The speed pulse wire is to tell the sat nav how far you have traveled, in between the GPS updates. Also it helps if your in a long tunnel and loose GPS signals for a while, also you dont need to wait for the satnav to find a signal when you first set off. For All Your Mini's Needs ![]() 01905 620011 |
| Connecting PIAA driving lights - Which wire is the high beam wire? | orbeamike | Exterior | 0 | Jul 22nd, 2005 04:52 AM |
| speed/pluse | den123 | Interior & Ice | 0 | Dec 29th, 2004 08:22 AM |
| Navigation speed sense Wire | PhoenixMiniS | Interior & Ice | 1 | Apr 24th, 2003 03:25 AM |
| Vehicle Speed Sensor Wire | suprchrgdmini | Interior & Ice | 0 | Jan 4th, 2003 02:39 AM |
| Speed Sense Wire | diverse | Faults & Fixes | 6 | Jun 14th, 2002 12:08 PM |
