Old May 6th, 2005, 07:20 PM   #1
lukebuzzy
Motoring since 8/4/04 :)
lukebuzzy's Avatar
Local Time: 06:45 PM
Trim below the door removal
Does anyone know how to remove the trim piece tha runs below the door. The seems to be a screw at the front (in front of the fusebox) but it doesn't have a head on it. How do i get it out?
Any tips would be apreciated. I'm removing it so i can get to a factory ground by the fusebox for my V1.
Thanks,
Luke
UK Expat - Oi Oi
2005 DS/DS MCS Sport Pack, Cold Weather Pack, OBC, MFSW, Leather Seats, Anthracite Headlining & Dash
United States View lukebuzzy's Dark Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 6th, 2005, 07:46 PM   #2 (permalink)
zuurg
Local Time: 01:45 PM
Canada
It's not a screw - it's a push-pin... it can be removed with a small flat-head screw driver or a small pair of needle-nose pliers. There are 2 more on the side near the seat - I had better luck removing mine once the seats were out) once you have those removed, the only thing holding the piece on is the bolt where the seatbelt attaches, and a bunch of clips underneath it...
Hope this helps
Canada View zuurg's Hot Orange & Black 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old May 6th, 2005, 08:00 PM   #3 (permalink)
lukebuzzy
lukebuzzy's Avatar
Thanks. Do I really have to remove the seat???
UK Expat - Oi Oi
Old May 6th, 2005, 08:31 PM   #4 (permalink)
GBMINI
Local Time: 02:45 PM
The trim piece inside the car, that runs alongside the seat?
I have removed it, more than once, in GBMINI#2 and I did not remove the seat. Jack the seat up as high as possible, and work around it - you will need to slide the seat back and forward a couple of times.
You have to remove the seat belt bracket too if you want to remove the trim piece completely.
Ian C. Gloucester, MA, USA (UK expat) driving GPMINI and Convertible GBMINI#6
United States Male View GBMINI's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 6th, 2005, 08:33 PM   #5 (permalink)
lukebuzzy
lukebuzzy's Avatar
Cool, thanks Ian!!!
UK Expat - Oi Oi
Wheel Arch Trim removal - help needed spikeyadrian Exterior 6 Feb 2nd, 2007 05:25 PM
Body Trim removal for Colour Coding. schapman Exterior 28 Dec 13th, 2004 08:35 PM
Wheel arch trim removal Pobsey Exterior 4 Dec 3rd, 2004 04:53 PM
Interior sill trim removal punkeyfunky Interior & Ice 2 Jul 12th, 2003 02:37 PM
Boot trim removal - rattle nigelmercier Faults & Fixes 5 Nov 13th, 2002 07:36 AM
