Carccessory.com
Old Jun 19th, 2005, 04:38 PM   #1
dcfkan
In exile, down SOUTH!
dcfkan's Avatar
Local Time: 02:06 AM
Manual Air-con cut off at certain (unspeakable) speed?
Has anyone else noticed that the chiller unit on manual air-con cut off when the car reached a certain (unspeakable) speed?
It happened to a certain souped up MCS I know
Just wondering
DK :apple:
United Kingdom Female View dcfkan's Chili Red & Lime Green 1st Gen MINI Cooper Profile   Reply With Quote
Old Jun 19th, 2005, 06:56 PM   #2 (permalink)
MrSpaz
Local Time: 01:06 AM
I have the auto A/C, but I'd imagine the compressor for either unit would disengage at higher RPMs in order to save the compressor. As you may or may not be aware, the compressor makes use of an electromagnetic clutch to grab the (otherwise neutral) pulley and turn the compressor. There's probably a sensor in the compressor itself that cuts the clutch when revs get too high.
I wasn't really paying attention to the air conditioner, but at ~ 125 mph the revs can climb pretty high. Amazingly the ride was still very smooth. Not as much vibration or noise as I would have expected.
Old Jun 19th, 2005, 07:13 PM   #3 (permalink)
UKC4
MINI2 Sex God & etc......
UKC4's Avatar
If it cuts out, i could only suggest is to route more power to the engine. Tell us the speed? You could of been on a race track for all we now!?!?!?!?!
Old Jun 19th, 2005, 08:03 PM   #4 (permalink)
r34ver
Sergeant Pepper
r34ver's Avatar
Send a message via MSN to r34ver
i find my aircon whines at high speed, at least i figure that it is the aircon because when i turn the ac off the noise stops.. coincidence?
SGT Pepper
United Kingdom View r34ver's Pepper White & Black 1st Gen MINI One Profile   Reply With Quote
Old Jun 19th, 2005, 08:07 PM   #5 (permalink)
aquabubble
This won't hurt a bit!
aquabubble's Avatar
It could be a number of things. My a/c went on the blink in my 206 GTI - high pitched whining - except that was at all engine speeds. Turned out to be the bearings and the whole unit had to be replaced (which is expensive I can tell you)! Don't want to worry you, but it could be an early sign of a possible future failure. Might be worth speaking to the service guys about it.
Old Jun 19th, 2005, 08:54 PM   #6 (permalink)
dietcokeplease
Official MINI2 Fluffer
dietcokeplease's Avatar
All a/c units on most cars are designed to cut out at generally more than 85% of the throttle opening. It's to give you the most power when you need it the most. So at very high speed it should cut out. It's normal and not a problem.
There is just one moon and one golden sun; And a smile mean friendship to ev'ryone; Through the mountains divide, and the oceans are wide; It's a small world after all.
Old Jun 20th, 2005, 07:17 AM   #7 (permalink)
Hat
Wolves Did It!
Hat's Avatar
the air con pump has its own cooling fan which cuts in when things get hot & its notoriously noisy - it could be that you're hearing
Manual Air Con Pics Hannibales 2nd Gen Interior & Ice 7 Nov 19th, 2006 07:52 PM
Automatic air-con 'v' manual? miniwilly Interior & Ice 10 Aug 9th, 2004 08:46 AM
Air con manual/auto silver_mini Interior & Ice 1 Jul 25th, 2004 11:00 PM
Sunroof? Worth it if I have manual air-con already? Toby General Discussion 30 Jun 13th, 2003 04:27 AM
Auto v Manual Air Con. nmottram Interior & Ice 9 Nov 11th, 2002 11:00 PM
