Think Mini
Old Jul 16th, 2005, 12:40 PM   #1
hugh1
hugh1's Avatar
Local Time: 05:54 AM
pre out voltage
In shopping for an aftermarket head unit, I find they are pretty consistantly rated at about 18wpc rms. This is not enough power to effeciently drive some better aftermarket speakers to their potential. OK I'll add an amplifier to my upgrade.
I know that unlike the oem unit, the aftmkt ones have rca outputs that connect with the amplifier...what I don't understand is their voltage specification. They all vary from 1v to 5v. The Alpines for example: 9851 & 9853 have 2v pre out...9855 has 4v...
What does the increased voltage do?
Old Jul 16th, 2005, 01:15 PM   #2 (permalink)
Crouchy
Doncaster MINI Register
Crouchy's Avatar
Local Time: 10:54 AM
The higher the voltage of the output the better. If the voltage is higher then the amp has a better signal to work with and will therefore produce a better sound. Go for the highest voltage you can find if you want good sound quality.
Old Jul 16th, 2005, 01:59 PM   #3 (permalink)
snid
brown is back
snid's Avatar
Within reason. There are good quality head units that will put out more voltage than some good quality amps are rated for.
I'm in this situation... everything works, even though I'm technically out of spec for the amp.
jtross | snid | jason - bloggage (including videos)
United States Visit my Blog at the Motorcade Male View snid's Velvet Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 17th, 2005, 01:01 AM   #4 (permalink)
SteveM3
SteveM3's Avatar
All RCA cables will be subjected to interference. The higher the signal the better as it
overrides the interference. Just think what you do, a friend can't make out what you are
saying because of a nearby lawnmower so you shout and they can understand you. So
generally high voltages are better but not always. Just as the most powerful amp or most
powerful car are not automatically the best.
England Male View SteveM3's Electric Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Charging Voltage crawfy Faults & Fixes 2 Jan 2nd, 2007 10:13 AM
12V voltage stabiliser mini one only General Discussion 3 Sep 6th, 2005 06:27 AM
O2 voltage = A/F ratio. Is it possible. obehave Engine & Drivetrain Tuning 1 Sep 2nd, 2004 05:36 AM
higher pre-out voltage than amp can handle (eclipse head units) snid Interior & Ice 1 Jul 14th, 2004 06:00 PM
Voltage help Hotelcalif General Discussion 0 May 26th, 2003 02:17 AM
