Visit Mini Mania UK
Old Jul 18th, 2005, 07:11 PM   #1
BlackStripe
Local Time: 10:35 PM
Silver Black Boost reception bad after car kit install
Hi.
Had a Nokia car kit installed recently, and all didn't go well. Install carried out by well known professionals..... the car kit works fine but my mini doesn't seem too impressed.
After initial install on very sunny day I noticed that the dashboard instrument lights remained on whilst the ignition was on. They no longer dimmed, problem was this was only spotted after the installation guy had gone.
So he came back, and it seems the wiring kit he used may have been for the 04 minis. mine is 05. The fix, after a bit of investigation was to cut one of the wires.
Then I noticed that the radio reception was worse. FM was ok where he did the install, but on a journey it fades in and out. AM has completely gone.
So my question is, is this just a case of forgetting to plug in an antenna lead? He is coming back in a couple of weeks to sort it.... could it be more sinister.... I don't know what the back of the boost radio looks like and whether the antenna is part of a connector block - hence impossible to get wrong.
Advice appreciated.
Old Jul 18th, 2005, 08:18 PM   #2 (permalink)
mikeythemini
I can't get no sleep
mikeythemini's Avatar
Local Time: 11:35 PM
dashlights - There is no difference between 04 & 05 radio wiring
radio bad - Sounds like he hs pulled out a pin or used the wrong interface. The aerial has an amplifier built in, it needs a live switched by the radio - if this isn't present you will get week FM & no AM, sounds like its no longer connected
Old Jul 20th, 2005, 09:45 AM   #3 (permalink)
brett
1st MINI Owner in QLD !!!
brett's Avatar
Local Time: 08:35 AM
Sounds like he cut a wire to stop the lights.
I agree with Mike with the cables being the same. I fitted a Nokia car kit into my 02 - Cooper than transfered the cable direcly into the 05 cooper S but I am a bit worried about him cutting the cable
1968 Mk1 Morris Cooper S 1310cc Downton Lake Green - White
1974 Leyland Mini 1098c Country Cream
2008 MINI Cooper S Chilli Pepper White - Black Roof
Australia View brett's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 22nd, 2005, 10:06 PM   #4 (permalink)
Mikes
Local Time: 04:35 PM
poor FM recption, BT installed also (sucks)
I also have poor FM recption AM ok,not sure if it was alright before B.T. install.
took it to the Dealer,they turned up the boost,no dif.
also is this true? Rremote top, only functions down,not up?
Also Blue Tooth is not worth the $ , we have disabled,calledr can't understand you.
any ideas?
thanks
mike
Old Jul 23rd, 2005, 12:15 AM   #5 (permalink)
mikeythemini
turned up th boost??
someone is pulling yur leg
No MW reception on radio boost!!! laurenceb Interior & Ice 2 Mar 29th, 2007 09:11 AM
Boost radio reception gone to hell Matt FT Interior & Ice 1 Jun 30th, 2006 04:20 PM
Bad radio reception as standard? AndrLync Interior & Ice 1 Jul 15th, 2005 11:34 AM
Crackly Reception on Boost Radio cook1e Interior & Ice 6 Jun 6th, 2005 10:25 PM
Just an FYI: Radio reception bad with Nav TeamF1Jr Faults & Fixes 5 Sep 2nd, 2003 08:55 PM
