Mini Pirate
Old Aug 9th, 2005, 07:06 PM   #1
Lord Hemming
You can call me Lord
Lord Hemming's Avatar
Local Time: 10:45 PM
Send a message via MSN to Lord Hemming
United-Kingdom Steering wheel gauges - USA option
I have been looking at Mini specifications over the pond and it seems additional gauges are available as an option in the USA. Does anyone have them, if so, what are the gauges for???? Can they be purchased as a non dealer fit accessory????
I am off to Houston Thursday for a couple of weeks, I may have to pop in to a dealer and bring some home
United States Male View Lord Hemming's Electric Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 9th, 2005, 08:14 PM   #2 (permalink)
Gr8Dain
Gotta Get Out More!!!
Gr8Dain's Avatar
Local Time: 11:45 PM
Really? Which ones? I have seen the guages under the switch panel. I have seen pods done by the aftermarket, but will have to look now.
Dain
United States Male View Gr8Dain's British Racing Green & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Aug 9th, 2005, 08:24 PM   #3 (permalink)
Lord Hemming
If you go to Miniusa.com and spec a Mini, go to the accessories area and it's listed with a picture.
Old Aug 9th, 2005, 08:37 PM   #4 (permalink)
twouptons
What's this button do?
twouptons's Avatar
The only gauges I see are the under-panel ones that go under the rocker switches.
They give you battery voltage and oil temperature.
You may be thinking of having the speedo and tach both on the steering wheel.
This happens if you get the Nav system or chrono pack, both of which put something else where the speedo normally goes. The chrono pack gives you oil temperature, oil pressure, water temperature, and fuel level, but no battery voltage.
There are also a number of people here who have fitted their own gauges, and I've seen a boost gauge or two on the steering wheel (though not fitted from MINI).
Hope that helps...
-Eric
United States View twouptons's Pepper White & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Aug 9th, 2005, 09:01 PM   #5 (permalink)
Gr8Dain
Gr8Dain's Avatar
I saw the column mounted ones. I don't think they are offered with the Chrono pack. I do remember seeing something like this once. The dials are not the same look as the speedo and tach so they don't look quite right. They are $325.
Dain
Old Aug 9th, 2005, 09:43 PM   #6 (permalink)
Lord Hemming
Yes, that's the one. I think they come up as Auxilliary gauges - steering. As you say, they're listed at $325. Anyone got a set???
Old Aug 10th, 2005, 12:10 PM   #7 (permalink)
ThomB
ThomB's Avatar
Local Time: 12:45 AM
Send a message via Skype™ to ThomB
I don't have them and have no need for them, but there is a guy local to me (Ohio, USA) that actually manufactures a mounting bracket (like the one shown) where you can add your own gauges. If you pop over to http://www.minineo.org post a question and someone should help you out with an answer. I've only met him once at a gathering and he had a trunk load of parts that he manufactures.
Thom
Thom * 2005 Hot Orange Cabrio * Pictures Here
United States View ThomB's Hot Orange & Black 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old Aug 10th, 2005, 08:39 PM   #8 (permalink)
willymcd
metal lord
willymcd's Avatar
Local Time: 08:45 PM
Send a message via AIM to willymcd
i have seen gauge pods like that before, i think alta makes one. this option is new, wasn't there 1 month ago when i speced my mini, which got here yesterday . besides the new gauge pods looks like there are new JCW options, like the carbon fiber bonnet scoop, carbon fiber mirror caps and carbon fiber rear door handle...
Old Aug 10th, 2005, 09:02 PM   #9 (permalink)
glassintrepid
I have them. There is a boost meter in PSI, and a Voltmeter. The boost meter reads 17 PSI to be in line with JCW cars. They are LED backlit and look the exact same at nightand are Stuart Warner guages. The hardest part of the install was getting the vaccum line through the firewall. The electrical connection plugs right into the back of the toggle panel. No splicing of wires, this alone was worth it to me. The fit and finish is nice, and it comes with a replacement panel that replaces the one just below the tach. There are several threads on Northamericanmotoring.com.
Depending on where you are going in Houston, there are two dealerships, MINI of the Woodlands about a 25 minute drive North from Bush airport on 45 North, and Momentum MINI on 59. Many houston people choose to go to MINI of the woodlands, because the service has been better. If you do end up wanting them, you will probably need to call. Mine were a few days on backorder. You will need to talk to David Shcaffer at the MOTW parts desk. Their number is 936-271-2900. Pm me if you need any more info. BTW, tell him glassintrepid sent you.
Here ya go.
http://www.northamericanmotoring.com...light=guag es
Is works steering wheel similar to bmw sport wheel? mcs_sam MINI Cooper S 11 Apr 28th, 2007 07:09 PM
New option: two steering wheels!!! rainbowdreamer General Discussion 11 Feb 11th, 2004 09:12 PM
do you need to get the Multifunction steering wheel option to get cruise control? dualceleron Interior & Ice 6 Aug 11th, 2002 01:34 AM
Another Aftermarket Wheel Option BobsCooperS Wheels, Tyres & Brakes 7 Jul 26th, 2002 12:16 AM
USA Mini option pricing now available S2000&CooperS General Discussion 1 Jan 8th, 2002 04:09 PM
