Think Mini
Old Mar 30th, 2007, 12:21 PM   #1
GP Thunder
Speeding along...
GP Thunder's Avatar
Local Time: 01:01 AM
Exclamation a better cold air intake?
Is there a better cold air intake for the MINI GP than the JCW intake without getting too extreme? I'm lookin for a bit more sound from it and a little more HP, and maybe in the future a straighter exhaust.
Old Mar 30th, 2007, 03:55 PM   #2 (permalink)
GARY GP
RMW-GP
GARY GP's Avatar
Local Time: 06:01 AM
Alta air intakes are very good, and you may find that lauder exhausts don't sound so good on the GP from the inside as their are no rear seats and no installation
Old Apr 1st, 2007, 02:05 PM   #3 (permalink)
PmP
GP 0380
PmP's Avatar
Take the flap out of the back of the airbox, makes quite a difference for free.
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 3rd, 2007, 07:38 PM   #4 (permalink)
GarethP
GarethP's Avatar
Local Time: 07:01 AM
Is this just a case of taking the top off the airbox and removing the disk?? Or does this need to have the vacuum pipe removed and plugged as well? I'm confused as to whether there is a blanking plate and a flap in the jcw airbox, or just the flap?? Haven't had a chance to have a look yet (5th day of ownership). Cheers.
Luxembourg Male View GarethP's Chili Red & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 3rd, 2007, 07:42 PM   #5 (permalink)
:: Jon ::
:: Jon ::'s Avatar
remove top of box.. remove flap and replce top
EMPTY SPACE NEEDS FILLING....
but it has to be something that wont get me banned
Old Apr 3rd, 2007, 07:45 PM   #6 (permalink)
GarethP
GarethP's Avatar
thanks ... but is this the flap that opens up at 4500revs, or another blanking plate??
sorry for repeating if this is obvious once looked at.
Old Apr 3rd, 2007, 07:53 PM   #7 (permalink)
:: Jon ::
:: Jon ::'s Avatar
just the flap..
Old Apr 3rd, 2007, 07:59 PM   #8 (permalink)
GarethP
GarethP's Avatar
ok - last question - the vacuum hose doesn't need blanking off or disconnecting??? is the sound noticeably different? performance noticeably freer below 4500revs???
Old Apr 3rd, 2007, 08:01 PM   #9 (permalink)
:: Jon ::
:: Jon ::'s Avatar
just the flap needs to be removed no need to touch anything else..
the supercharger noise will be enhanced and also the noise you would normally hear over 4500revs is the noise you will hear from 1rpm once the flap is removed
Old Apr 4th, 2007, 12:20 AM   #10 (permalink)
Coilte
MCS/JCW
Coilte's Avatar
is there any danger of damage through removing the flap, sorry not the most technically minded!
Old Apr 4th, 2007, 12:43 AM   #11 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
No. It's only there to reduce the supercharger whine at lower revs.
It was acceptable in the 80's
Old Apr 4th, 2007, 12:57 AM   #12 (permalink)
Coilte
MCS/JCW
Coilte's Avatar
Well i am taking it out tomorrow, why would you want to reduce the sc whine, its a great characteristic!!
Old Apr 4th, 2007, 01:32 AM   #13 (permalink)
Root Ginger
That's what happens when you make cars for the general public. The majority of people want a quiet car. Then there's a lot that want a quiet car but that makes a noise when you give it some stick. This is what the flap achieves.
Old Apr 4th, 2007, 11:52 AM   #14 (permalink)
GP Thunder
Speeding along...
GP Thunder's Avatar
Thumbs up
How long would you say this would take to do? Usually the less time, the less complicated it is....
Also, has anyone noticed the attachment inside the hood beneath the hood scoop rubbing or "melting" do to it coming in contact with the cooler on the top of the engine?
The service person gave me the idea that this may be a common occurrence with this JWC attachment and that it will only be replaced once.
Old Apr 4th, 2007, 12:31 PM   #15 (permalink)
GarethP
GarethP's Avatar
I get the melting foam around the cooler as well. Annoying.
You would have thought they would have found a foam that didn't melt!!!!
Comes off when cleaned...
Old Apr 4th, 2007, 12:52 PM   #16 (permalink)
Coilte
MCS/JCW
Coilte's Avatar
Anyone got pictures of the inside of the JCW airbox, as per my earlier post not technically minded and would be good to know how where exactly is the flap, say if your facing the engine bay/airbox??
Old Apr 4th, 2007, 01:34 PM   #17 (permalink)
PmP
GP 0380
PmP's Avatar
Guys this is dead easy. Took me about 30 mins once I had finally got lid off, rear hooks can be tricky. You cant miss the flap its at the bulkead/cockpit side of the airbox. I would read this before attempting it.
Removing Flap
1. Remove the clip on the pipe leaving the airbox lid (mine was a jubilee clip, standard clip on GP is a use once item). This is the pipe going to the engine, so I put a vinyl glove over it to stop any dirt going down it.(Not necessary)
2. Lift battery termainal connection on the side of airbox lid out of the way.
3. There are two torx screws at front of airbox lid, undo these, they are intergrated into the lid, so no risk of dropping them into the engine.
4. push the lid back with pressure, it should slide back about 10mm. Then lift the lid keeping it level horizontally. As there are two clips at the back of the box which sometimes arent easy to unhook.
5. Once I had lid off I covered the pipe with another vinyl glove to keep dirt out of clean sie of filter.
6. Be careful at all times as the vacuum pipe is still attached.
7. The flap at the back opening of lid will be visible and u will be able to operate it by hand.
8. Take a look at construction of the airbox to familiarise yourself with how it works. Looking at the outside of it, you will see four screws around the actuator that operates the flap.
9. Remove theses screws carefully, as you could drop them into the engine, put a sheet or towel below the lid is a good idea.
10. Once removed, the actuator will come away from the lid. Then you get lift flap away.
**(I took the opertunity to gently hoover the filter on dirty side and the inside of the airbox.)**
Rebuild it now.
11. Replace the actuator minus the flap, and replace the four screws.
12. Set the airbox lid back down on the the bottom of the airbox, making sure the rear hooks catch, and tighten up the two front torx screws. Make sure you dont catch the vacuum pipe in wrong place.
13. Take the two vinyl gloves off the pipes, and reattach the pipe to engine with jubilee clip.
14. Replace battery terminal on its mount.
***Remember you will need a new jubilee clip the correct size if its a GP or factory fit JCW conversion. Can be got in any good hardware store, or Mini dealership should be able to provide one. Also jubilee clip does same job but is reuseable.***
I did this modification to my S and its made a decent difference. Made my car whine below 4500rpm again, if its on a GP or JCW heavens knows, the whine will be awesome.
Old Apr 4th, 2007, 01:50 PM   #18 (permalink)
GP Thunder
Speeding along...
GP Thunder's Avatar
Thanks for the input on the intake issue! Just lookin to do a few possible mod's that wont cost its collectibility in the future.
Old Apr 4th, 2007, 07:05 PM   #19 (permalink)
Coilte
MCS/JCW
Coilte's Avatar
PmP
PmP many thanks for your pointers, they were spot on I removed the flap this evening, just come back from a drive and you can definately notice the difference in the lower rev range, the torque just allows (and feels) the car to pick up speed more quickly, and the extra noise from the s/c at low revs is a great addition, cheapest mod and glad i have done, only take 20 mins/30mins half hour to do and i would recommend it to everyone (that is applicable).
Old Apr 5th, 2007, 10:43 PM   #20 (permalink)
PmP
GP 0380
PmP's Avatar
Excellent.
Ive a JCM airbox sitting here, looking help on reversing the vacuum pipe connections that occur when upgrading to JCW airbox. Have BMW instructions, but the diagrams arent clear, cant find the vacuum pump were the connections are altered, help someone, are the below the airbox?
difference cold air intake and normal air intake filter falconetti Engine & Drivetrain Tuning 17 Apr 13th, 2006 09:53 AM
ProMini Cold Air Intake VS Alta Cold Air Intake??? SS Mini Engine & Drivetrain Tuning 5 Dec 13th, 2005 12:48 AM
Removing air intake hose in order to fit cold air intake system Spoony Engine & Drivetrain Tuning 7 Jul 29th, 2005 02:41 PM
Cold air intake benefits? BigGerald Engine & Drivetrain Tuning 4 Jul 12th, 2005 10:43 AM
Cold Air Intake w/ JCW? RobbieD Engine & Drivetrain Tuning 2 Jan 26th, 2004 03:08 AM
