| Tags: brake pads, rust, tires |
| GP 1986 Join Date: Apr 2002 Location: Provincia di Cuneo Local Time: 04:05 PM
Offline | Hi All A few things: 1. Got my front tires changed this week. Last time it was to replace the horrid Dunlop runflats to the Michelin Pilot Sport PS2 205/40/18 Extra Load. They are so great, I got another pair. The back tires are still in great shape. Long run with them!! Highly recommended. Each tire including installation cost me 235 euro including IVA (tax). 2. Had my front brake pads replaced at last. Got a pair of “34116770251” - REPAIR KIT, BRAKE PADS - JURID 612. My question is: how much did you pay for yours? I paid 126.43 Euro not including IVA or installation (which was another 30 euro). Was this a good price? Bad price? Please share your costs so I can compare. Thanks 3. My roof number: Well, they managed to order the “6” which as I reported a while ago, fell off. I was pretty surprised, but they said it would take a few weeks. Will wait and see if it will be under warranty or not. Will report back once I get it. 4. Now, I have noticed some serious rust in the engine bay area. See below photos I took. The dealer (“Target” in ASTI Italy) said (and this is after he checked with the main tech guy there) that this is normal, and happens a lot. Nothing to be done, and they can’t replace it – would mean to take out the complete engine etc. I feel this is bs, and wanted to check with you all and see if you have the same problem and if you managed to get it resolved. I think I should write/contact BMW Mini UK or Italy and see what they say. But If I were out to buy a car and noticed this kind of rust, I would probably stay away. Please let me know. thanks Cheers, Lorien |
| Heading down the aisle | Go back to your dealer. That is not normal, it doesn't happen a lot & they don't all do it. They just don't want an expensive warranty claim. Push, Lorien, push. (All of the above is based on the assumption that there shouldn't be any rust in the engine bay in a year old car.) Edit: I just went and opened the hood-- I have the tiniest bit of discoloration on the chamfered edge that you can see in your 3rd photo. |
| MINI2 Master Join Date: Jan 2007 Location: Earl Shilton, Leics. Local Time: 02:05 PM
Offline | I would not be worried at all by that rust, and I would be inclined not to let a dealer fix it! the amount of tearing apart of the engine bay to get that sorted would more than likely cause far more problems! |
| | #6 (permalink) |
| I miss my MINI | I agree with Jamie on this. The engine block is iron and surface rust is going to happen (has on mine as well in roughly the same spot). Having the dealer tear into it is likely to cause more problems than it is worth and will probably just happen again. Global Moderator ![]() |
| | #12 (permalink) |
| AFRacing | I've seen loads of W11 engines like that. Its not a issue as such, just cosmetically not pretty. ROver had a problem with the old Mini A-series at the end of production that caused the same problem. It was put down to not washing the blocks enough and getting rid of all the sand from casting. Alex Alex F - AFRacing LTD |
| | #13 (permalink) |
| Addicted to Speed!! Join Date: Sep 2001 Location: ..."B" roads!! Local Time: 02:05 PM
Offline | Wouldn't worry about that rust. As was stated it is a cast iron block so it will rust. I have the same on my Works. Just rubbed it down a bit where I could and painted it with some silver engine paint about 6 months ago and it it hasn't come back. ![]() |
| Surface rust on brake discs | South Shore Lad | 2nd Gen Faults & Fixes | 10 | Feb 8th, 2007 04:05 PM |
| Which AFTERMARKET brake pads will be compatible with brake sensors? | wrxtomini | Maintenance & MINI Care | 0 | Apr 22nd, 2006 03:17 PM |
| rust on brake discs (ignore) | Steve P | Wheels, Tyres & Brakes | 1 | Oct 23rd, 2004 09:11 AM |
| new alloy and tyres will i need to get new brake discs and brake pads | TREBALZ | Wheels, Tyres & Brakes | 7 | Sep 23rd, 2003 11:24 PM |
| Does anyone have rust on the brake discs? | chuckie | Faults & Fixes | 10 | Jan 22nd, 2002 04:14 PM |
