GizzmoUSA
Old Oct 6th, 2004, 12:41 PM   #1
GTT 280
The Power Cube
GTT 280's Avatar
Local Time: 06:14 AM
United-Kingdom MCS Works Air intake
Hi,
Can anybody confirm the following...
JCW garage stated some time back that the airbox should not be replaced due to increased airflow and strain on the injectors.
Now the new JCW kit has a flap that opens - is this correct ?
Are the injectors modified to cope with the increased airflow ?
Thanks,
CSW.
Old Oct 6th, 2004, 01:36 PM   #2 (permalink)
phaedrus
MINI2 Irregular
phaedrus's Avatar
Local Time: 01:14 AM
Send a message via MSN to phaedrus
JCW air intake
Yes, the flap opens at 4500 rpm -- where greater airflow is actually needed -- drawing air from under the left pollen bezel. But that's all the intake really is -- the stock intake with an added flap, actuator, and JCW logo. I'm assuming they chose this 'cost-effective' way in order to keep the JCW kit's price in check.
That's a good point about the strain on the injectors, though -- I've always wondered if there were any such issues with adding an after-market intake, as well as why JCW initially did not choose to modify theirs.
During some independent testing, an acquaintance with the previous JCW package installed found that the fuel mixture ran too rich at high throttle. This likely means that not enough air is mixing with the fuel for proper combustion. Naturally he opted for an after-market air intake and the problem quickly went away.
Canada Male   Reply With Quote
Old Oct 6th, 2004, 01:41 PM   #3 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
United-Kingdom
Hi - interested how you determine that the fuel mixture if high or low. Do you connect your laptop to the car and run software that reads the output from the ECU ? You'd think a multi-billion pound business would get all this correct ???
Old Oct 6th, 2004, 02:47 PM   #4 (permalink)
obehave
Mini Mod
obehave's Avatar
That last bit is a little contrary to a lot of information that has been posted here.
The MINI runs rich, period.
Intake, exhaust, 15% pulley and throttle body on one and it'll still run rich. The rich mixture is intentional at full boost and is used to help cool the supercharger.
Just changing out an intake isn't really going to make much difference.
The stock injectors seem to be fine at 200 or so BHP.
Old Oct 6th, 2004, 02:53 PM   #5 (permalink)
GTT 280
The Power Cube
GTT 280's Avatar
United-Kingdom
So increased airflow is fine then....
....and furthermore, how do people analyse all of this? - can i buy software for my laptop ?
Old Oct 6th, 2004, 03:08 PM   #6 (permalink)
obehave
Mini Mod
obehave's Avatar
Increased airflow up to the usual mod level( what I listed above basically) is fine.
At a minimum a wideband O2 sensor and a good gauge will get you decent A/F ratio data.
There's many far more knowledgeable people than me here. Andy@Ross-Tech.com is very good and has posted a number of times about the wideband O2 sensor.
Old Oct 6th, 2004, 04:24 PM   #7 (permalink)
jwardell
jwardell's Avatar
Online
Send a message via AIM to jwardell Send a message via Skype™ to jwardell
For that to be true, the gas would have to be injected into the air stream before the S/C. Perhaps you meant engine. Many ECUs will richen the mixture when the engine starts to overheat to help cool it.
United States Male View jwardell's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 6th, 2004, 07:28 PM   #8 (permalink)
obehave
Mini Mod
obehave's Avatar
Ooops. Air charge
You're correct, the intent is to cool the air charge to help suppress any detonation tendencies.
Works air intake fitting help NickG Engine & Drivetrain Tuning 19 Feb 28th, 2007 02:36 AM
Air intake for MCS adoreableyuja Engine & Drivetrain Tuning 4 Sep 17th, 2006 05:01 AM
difference cold air intake and normal air intake filter falconetti Engine & Drivetrain Tuning 17 Apr 13th, 2006 09:53 AM
Removing air intake hose in order to fit cold air intake system Spoony Engine & Drivetrain Tuning 7 Jul 29th, 2005 02:41 PM
And the JCW's air intake on the MC Works is actually made by.... Adventure_Man John Cooper Works & GP 12 Apr 11th, 2003 02:26 PM
