| Lloyd Blackpool MINI Sales - Servicing - Parts |
| | LinkBack (16) | Thread Tools | Rate Thread |
| Hi Chris, the ref. nr. for the kit what you sell it's :34.11.0.432.802 if i have a VAT registred company in Romania you sell me this with how much? how much it cost the shipment to Romania? Last edited by klaude2_2; May 5th, 2009 at 08:40 PM. |
Chris, I already have these brakes fitted to my new 57 clubman D and I was unsure if the space saver wheel will still fit over the rear calipers as i do not have run flats. If not how can i get it to fit or what wheel could i use as a spare? Cheers Gaz |
| Hi Chris, If this offer is still running, I would be interested and a friend of mine as well. Please could you give me the total cost including shipping to France for 2 kits at the same address. Thank you. Last edited by bertrand; Jul 24th, 2009 at 09:11 AM. |
![]() ![]() ![]() Chris I am puzzled ![]() Mind you that is not difficult. ![]() The rear disc on the JCW retrofit is 280mm dia. The front disc on a clubman diesel is 280 mm On an S the front is 294 mm I believe. The front caliper on both is bigger than the rear caliper or at least the same size, so if a space saver will fit on the front of an S or clubman diesel then why would it not fit on the rear of the JCW retrofit setup???? All it would mean is when you get a puncture on the front, you would have to transfer a rear to the front then fit the spacesaver to the rear. Unless of course there is a scientic reason why the spacesaver will not fit the rear. I suspect the only real way is to physically try |
| Hi You are spot on, the only reason they don't list a space saver for the works is the big front brakes and the centre exahust so you would need to swop and change wheels around if you picked up a puncture on the front,it would be a bit of work at the side of the road in the rain but not a problem,if you did go for the space saver wheel and tyre it would be £93.00 inc vat, cheers Chris |
| Tags: all_gen_brakes, announcement |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/lloyd-blackpool-mini/161796-special-offer-john-cooper-works-brembo-brake-kit-r56.html | ||||
| 07 Cooper S Brake Upgrade | This thread | Refback | Mar 24th, 2009 09:52 PM | |
| 07 Cooper S Brake Upgrade | This thread | Refback | Feb 15th, 2009 01:05 PM | |
| 07 Cooper S Brake Upgrade | This thread | Refback | Feb 10th, 2009 10:06 PM | |
| 07 Cooper S Brake Upgrade | This thread | Refback | Feb 9th, 2009 09:11 PM | |
| 07 Cooper S Brake Upgrade | This thread | Refback | Feb 2nd, 2009 01:41 PM | |
| MiniSpirit.Com • Vendo Tópico - Compravam JCW Brembo Brake kit? | This thread | Refback | Jan 23rd, 2009 11:47 PM | |
| 07 Cooper S Brake Upgrade | This thread | Refback | Jan 12th, 2009 10:55 PM | |
| 07 Cooper S Brake Upgrade | This thread | Refback | Jan 10th, 2009 03:12 PM | |
| 07 Cooper S Brake Upgrade | This thread | Refback | Jan 10th, 2009 06:32 AM | |
| 07 Cooper S Brake Upgrade | This thread | Refback | Jan 8th, 2009 11:55 AM | |
| 07 Cooper S Brake Upgrade | This thread | Refback | Jan 8th, 2009 07:21 AM | |
| 07 Cooper S Brake Upgrade | This thread | Refback | Jan 7th, 2009 07:20 PM | |
| 07 Cooper S Brake Upgrade | This thread | Refback | Jan 7th, 2009 05:38 PM | |
| MiniSpirit.Com • Vendo Tópico - Compravam JCW Brembo Brake kit? | This thread | Refback | Dec 9th, 2008 10:24 PM | |
| MiniSpirit.Com • Vendo Tópico - Compravam JCW Brembo Brake kit? | This thread | Refback | Dec 1st, 2008 06:33 PM | |
| MiniSpirit.Com • Vendo Tópico - Compravam JCW Brembo Brake kit? | This thread | Refback | Dec 1st, 2008 05:51 PM | |
| R56 John Cooper Works Aero Kit | minimagic | Second Generation Works | 7 | Apr 21st, 2007 09:59 AM |
