Hi Bertrand,
the offer is still on, if you have two kits they would be £1050.00 each kit including shipping, delivery would be aropund 5 days to you i have plenty of the kit in stock,
thanks
Chris
Hi guys.
Just a little update on space saver wheel fitment with JCW 4pot BBK.
I have recently fitted these to my Clubman D
I have the spacesaver spare which fitted the standard brakes.
After fitting the JCW BBK I found that the spacesaver would NOT fit on the rear without catching the caliper.
For some reason it is bigger than the standard front caliper fitted to the D, although the disc size is the same
Anyway after some lateral thinking I made up a mock spacer of 20mm thickness and tried this on the rear wheel. BINGO the wheel now turns without catching
So it appears that if you want the JCW BBK 4 pots and want to carry a space saver instead of the GOO you need a 20 mm spacer and some longer bolts.
This solution should apply all R56/55 minis.
Also remember it is only a get you out of the S*&^T solution and NOYT for traveling long distances
(These are my findings but cannot be held responsible for any problems you may find)
Chris I am puzzled Mind you that is not difficult.
The rear disc on the JCW retrofit is 280mm dia. The front disc on a clubman diesel is 280 mm
On an S the front is 294 mm I believe. The front caliper on both is bigger than the rear caliper or at least the same size, so if a space saver will fit on the front of an S or clubman diesel then why would it not fit on the rear of the JCW retrofit setup????
All it would mean is when you get a puncture on the front, you would have to transfer a rear to the front then fit the spacesaver to the rear. Unless of course there is a scientic reason why the spacesaver will not fit the rear.
I suspect the only real way is to physically try [/quote]
Hello Chris,
By any chance can you provide the discs and brake pads seperately?
I've got the big brake conversion on my clubbie JCW 4 pot with 316mmX2Omm and rear 280mmx10mm.
By the way Shipping to Portugal.
Hi
Thanks for getting back to me
i can supply the Brembo brake set,including shipping the total cost would be
£1580.00 GBP.
I have the brake kits in stock and delivery to you would be ten days
if you have any questions or wish to order just let me know
Chris
