Performance Torque
Old Jul 3rd, 2002, 06:04 PM   #1
mike58
Local Time: 09:34 AM
Tyre Wear Cause for concern??
I have gone through a set of front Pirelli 3000s 175/65/15s in 8000 miles.
This is not unusual I hear.
Obviosly driver style is a major factor but my OTHER car a Porsche 911 gets over 10/12000 on the rears.
The other sinister factor is that the wear is in the centre of the tyre and I run at reg checked manufacturers press ie 30-32 psi.
Mmnnn??
Scotland   Reply With Quote
Old Jul 11th, 2002, 02:45 PM   #2 (permalink)
jmardy
Local Time: 01:34 AM
If you are wearing the inside of the tire first, it usually indicates over-inflation.
I would try running at lower pressures.
Try 28psi. Measure and record tread depth on inside, center, outside. Drive for a month, compare tread depth, adjust pressure as necessary.
Note: if you have more negative camber, the inside will wear faster and will make the above method less useful.
8000 miles is short, but these tires are very narrow and are subjected to a lot of force.
I would get wider tires.
IMHO
YMMV
blah blah
-John
Tyre Wear KillerByte Wheels, Tyres & Brakes 1 Jan 27th, 2007 01:51 PM
Would you like to send a prepared letter to Mini expressing concern over roof wear? rentagas MINI Convertible 38 Oct 4th, 2005 11:44 AM
Tyre wear timmy Wheels, Tyres & Brakes 4 May 2nd, 2004 01:39 AM
Tyre Wear scooper MINI Cooper S 10 Mar 9th, 2003 05:04 AM
Tyre wear willibobs Faults & Fixes 7 May 9th, 2002 05:41 PM
