Cooper S Battery Life - Page 2 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #16 (permalink)
Old May 2nd, 2006, 04:04 PM
Prowse's Avatar
Send a message via MSN to Prowse Send a message via Skype™ to Prowse
Local Time: 06:20 PM
United Kingdom Male View Prowse's Astro Black & Body Color 2nd Gen MINI John Cooper Works Profile
Quote: Originally Posted by endofnight
Not quite an answer, as I've got 9 months on my car, but when you replace it, is there any battery out there not made of lead? I'm not that keen on acid either. Having paid $400 for a rear wind deflector for my convertible, who would doubt I'd pay the same for a lighter, better, longer lasting battery (one which doesn't require I keep the motor running while I put up my top).
Automotive battery manufacturers make two basic kinds of battery, one that provides you with a high current punch (SLI battery) - perfect for starting a car, the other is a deep-cycle battery, used for golf carts. You should not run an SLI battery more than 80% flat (60% for a gel battery), and you should not put high loads (car starting) on deep-cycle batteries. So really your car should carry two batteries - one for starting, one for operating the roof. This would increase weight by a few kilo's so consequently car manufacturers prefer you to either keep your engine running, or top-up (charge) your battery regularly.
Apparently manufacturers are working on Zinc-Air batteries and Nickel-Metal-Hydride batteries capable of starting a car, but these are are still in development.
The best you can do at the moment is make sure your old batteries are recycled properly and keep your current battery well charged. I've just bought a charger from these chaps - most impressive bit of kit...
http://www.ctek.com/en/home.asp
  #17 (permalink)
Old May 5th, 2006, 08:50 PM
RedMini's Avatar
England View RedMini's Chili Red & Body Color 1st Gen MINI Cooper S Profile
I was talking to someone today who has bought a marine battery for his classic Mini that is only used occasionally. Do you reckon that's a good way to go?
MCS JCW CR/CR ; MOD LY/B
  #18 (permalink)
Old May 13th, 2006, 03:48 PM
Prowse's Avatar
Depends on what you're using it for. If it's for starting the car, then no. Marine batteries are deep-cycle batteries, designed for running low current appliances. They should not be used for the high current demand of car starting. I'd just stick with the normal battery.
  #19 (permalink)
Old May 14th, 2006, 03:57 PM
RedMini's Avatar
Thanks for that - I think he only used the car about once a month and was planning to use the marine battery to keep the alarm and tracker going in between times.
As you say, the ideal would be to have one battery to power the alarm and another to start the engine but think I'll make do wth the standard battery and make sure it's kept charged if the car isn't used for a while.
  #20 (permalink)
Old Dec 27th, 2012, 02:38 PM
Rudolph Hucker's Avatar
Local Time: 07:20 PM
England
May 2003 MCS, original battery! I've done 65,800 miles but haven't driven it much at all this year, in fact it hasn't been started for 2 or 3 months and I know the battery will be flat. I've resurrected it from dead twice already so I guess I'll have to get a new one now. I've been very impressed with the battery, which I've never laid eyes on and am interested to find out what make and capacity it is, that's if I can find it )
  #21 (permalink)
Old Jan 20th, 2013, 11:46 AM
England Battery
Nov 2003 cooper S 60,000 miles from new on original battery, when it comes for replacement i'll prob go for another Bosh battery. car hasn't been used for a couple of weeks, checked the battery indicator yesterday was showing black not green,still started ok( but not a fast turnover 0c outside air temp).
  #22 (permalink)
Old Jan 24th, 2013, 03:08 PM
Battery
Tried to start the car today, hasn't had a good run for two weeks now, would not start,checked out replacement battery prices from Halfords,Euro car parts ect, but these were for a 45Ah battery were mine is a 55AH,
phoned the local BMW/Mini dealer,£102 for an original replacement 55AH battery(which i thought was going to be mega bucks)
When changing over the battery used a spare 12v 17AH motorcycle battery jumped onto the engine bay connections, so as not to cause any problems like spikes or having to reinitialise the key fob.
  #23 (permalink)
Old Jan 24th, 2013, 03:35 PM
Online
United-Kingdom
Minis with stop start and brake energy recycling have AGM
batterys fitted as standard. These can stand heavy discharge
and high recharge rates. I think it stands for Absorbed Glass
Mat (AGM) if you were wondering.
  #24 (permalink)
Old Jan 24th, 2013, 06:06 PM
Cooper S Jon's Avatar
if the battery size is 242x175x175 D21 (075) Varta Silver Dynamic Car Battery 12V 61Ah 561400060 - Car Batteries - Varta Car Batteries
5 year warranty
  #25 (permalink)
Old Jan 26th, 2013, 10:47 AM
England Battery
Thanks for the info Cooper S Jon, the Varta battery is half the price and a higher AH rating,but thats an online price( next day/two day del time) but i needed something off the shelf quickly, and considering the original battery lasted 9 odd years,which is good going, i thought i'd go for exactly the same unit, plus stops the ol lady giving me jib cause her motors off the road
  #26 (permalink)
Old Jan 26th, 2013, 03:00 PM
Just had to replace my MCS battery which was the original 2003 factory fitted unit with 65,000 miles under its belt.
If you are a member of the RAC worth checking their deals as they supplied and fitted mine (at home) for £95.
Also, be careful when ordering or buying a replacement MCS battery as it needs to be taller than many of the batteries listed as replacements at most motor factors otherwise it won't be secured by the top clamping bar in the boot.
Finally, watch out for removing the clamping bar retaining bolt. Mine sheared off in the captive nut in the boot floor due to corrosion. It took the RAC guy ages to drill out the end of the old bolt and re-tap the thread for a replacement. Glad he had to do this rather than me as I nearly went to Halfords to buy and fit the replacement myself!
Spike
  #27 (permalink)
Old Jan 26th, 2013, 04:04 PM
England Battery
Looks like i was lucky with my battery change,as the clamp bolts came out easy, took me about 10 min's to remove and replace.
  #28 (permalink)
Old Feb 28th, 2013, 08:11 PM
Replaced mine couple months ago, it went dead first day I had it, all that showing off with the doors open!
It was a 2002 cooper with 93000, so was about time to get a new battery!
Got it from euro car parts...
  #29 (permalink)
Old Mar 9th, 2013, 10:01 AM
Aussie Newbie
Local Time: 04:20 AM
Australia Male
Replaced the original battery in my car today.
March 2004 Cooper S. 280,000km (174,000 miles)
Promini Cooper Battery Cover BUTTONMUSH Wheels, Tyres & Brakes 0 Jul 2nd, 2006 06:18 PM
Cooper S Flat Battery!! jasonfields007 First Generation MINI Cooper S 3 Feb 1st, 2006 06:04 PM
Low profile battery cover for Cooper Maaij First Generation MINI Tuning 0 Nov 8th, 2005 02:19 PM
How long is Remote Key battery life, please? dcfkan First Generation Faults & Fixes 43 Sep 3rd, 2005 08:48 AM
Battery Life on TomTom Go Streeb-Greebling First Generation Interior & Ice 10 Feb 16th, 2005 12:51 PM
