Hi all,
I am hoping that somebody can provide me with some information to this problem...
My 03MCS is overdue for its 70,000 mile service, which is I believe just an oil change - the car is booked to go in on the 1st Feb.
Ever since the countdown has reached -500 miles, the power output from the engine appears to be down - that surge from between 3500/4000 rpm is not there anymore.
Also, this morning on the M25, dropping to 4th and applying full-throttle now results in a nice display of engine and EML lights on the dash, accompanied with NO acceleration what-so-ever in any gear, just a 900 rpm idle speed - limp-home mode I assume.
Anyhow, coasting to the hard-shoulder and then switching-off the engine and then on-again appears to "reboot" the management system, so that I can now actually drive the car and accelerate properly, albeit without the usual surge. This happened twice this morning.
My questions are:
1. Does the management system reduce the power output if the service interval is over-run?
2. Is it normal behaviour for the "limp-home" to kick-in during a "reduced power mode", or is it likely to be a symptom of something more sinister?
Cheers!
PS Its my birthday today!
