Closed Thread
Old Feb 2nd, 2006, 05:26 PM   #1
:: Jon ::
Banned
:: Jon ::'s Avatar
Local Time: 07:57 AM
How To Change Brake Pads. (F&R)
FRONT
remove the wheel
remove the top from the brake fluid tank in the engine bay
now pull the pads out.. if tight use a long flat blade screwdriver to ease the piston back being careful not to damage the disc.
now remove the pads.
using a cloth to protect the discs leaver the pistons as far back as they will go using the screwdriver.
now place some copper grease on the back of the new pads
place the outside pad (the one with the clip) in first then slide the rear pad in. some force may be needed unless the piston is as far back as possible.
now this one is done
replace the wheel and repeat on the other side.
here is an exploded view of the front bakes
REAR
remove the wheel
this time undo the caliperby removing the 2 bolts from the rear of it (top & bottom)
now remove the pads..
to push the piston back, you need to push and turn it at the same time.
use some long nose pliers to do this as the correct tool is around £90
place the outside pad in first then slide the rear pad in. some force may be needed unless the piston is as far back as possible.
bolt the caliper back into place
place the cover back onto the brake fluid tank.
here is an exploded view of the rear
job done..
just start the car and press the brake pedal for the pads to move and be seated into the correct postion.
take it easy for a couple of miles as they will bite quite harsh.
if you require any more info just PM or Page me.
Scotland Male
The Following 2 Users Say Thank You to :: Jon :: For This Useful Post:
Closed Thread
Brake discs & pads icclebug Wheels, Tyres & Brakes 13 Jun 19th, 2007 07:38 PM
How to change Brake Pads w/ pics (F only) bryce03 Maintenance & MINI Care 2 Oct 22nd, 2006 04:19 PM
Brake Discs & Pads STOYS General Discussion 1 Aug 4th, 2004 02:08 PM
Mintex pads & brake sensors jblow Engine & Drivetrain Tuning 0 Apr 5th, 2004 04:27 PM
