Wipac
Old Feb 24th, 2006, 11:03 PM   #1
yellow02
Local Time: 01:57 AM
Send a message via Yahoo to yellow02
Reset miles and oil inspection light
Hi, I own a 2002 mc with out a owners manuel I need to reset the miles inspection light but I dont know how? Also how would I reset the oil light? thank you for your help
Old Feb 25th, 2006, 12:15 AM   #2 (permalink)
Widgey
Widgey's Avatar
Local Time: 10:57 AM
A dealer will re-set the service interval indicator for you after each routine service but if you want/need to re-set it yourself then...
1) With the ignition turned off, press and hold the trip meter reset button (it's on the RH side of the speedo near the base)
2) Turn the ignition switch to position 1
3) After about 5 seconds, the display (in the speedo) should read Oil Service or Inspection with the words reset or re
4) Release the button then press it again and hold it. After about 5 seconds the word reset or re should flash/blink
5) Release the button, press it and then release it again. The new service interval should now be displayed
6) Press and release the button once more and it should say End SIA
7) Turn off the ignition (i.e turn the key back from position 1)
And that's how to re-set the service interval indicator
United Kingdom Male View Widgey's Chili Red & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Feb 25th, 2006, 12:51 AM   #3 (permalink)
yellow02
OK I tried it , and failed. I keep getting into the TEST mode. Test mode 1 2 10 and 19 and test mode 0 doesnt show anything....Im lost ? Help!?
Old Feb 25th, 2006, 02:32 PM   #4 (permalink)
yellow02
OK never mind I got it to work, I guess I was to slow the first times I tried. Thanks!
Old Feb 25th, 2006, 06:28 PM   #5 (permalink)
Widgey
Widgey's Avatar
Happy to have helped
Just Had My Oil Service inspection ombler Wheels, Tyres & Brakes 2 Jun 24th, 2006 09:47 AM
miles to inspection arowana Faults & Fixes 1 May 2nd, 2006 06:51 AM
Last Miles Inspection, dealer want $500!! Help me please Chilipeppa03 Maintenance & MINI Care 7 Jan 10th, 2006 11:08 PM
Miles to Inspection Query SarahC Maintenance & MINI Care 2 Apr 11th, 2005 08:33 PM
oil service light after 200 miles Kinster Faults & Fixes 13 Jul 1st, 2003 01:52 PM
