Removing Persistant Alloy Stains!??? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 27th, 2006, 06:09 PM
GR33NIE's Avatar
Polo GT Owner!
Send a message via MSN to GR33NIE Send a message via Yahoo to GR33NIE
Local Time: 01:43 PM
England Male
Anyone know the best product to get rid of persistant alloy stains! Please see attached, tried a few things now and it won't go!
Basically little speckles of brake dust stuck on the wheel!
ID:	113012   Click image for larger version
Old Mar 27th, 2006, 06:16 PM
Redwytch's Avatar
Having a Mini Adventure!!
Send a message via MSN to Redwytch
Local Time: 02:43 PM
United Kingdom Female View Redwytch's Electric Blue & Black 1st Gen MINI Cooper Profile
Personally I use Turtle Wax Extreme Wheel cleaner, it does the job without being too harsh on the alloys and their coating. A lot of folks love Wonder Wheels, but it can dissolve coatings and lead to the wheels loosing shine and protection, which long term isnt good. If you've tried everything else then there are a few places that can refurb the wheels, usually at a cost of between £30 and £50 per wheel. The process involves having the wheels sandblasted and then recoated with laquer. Not cheap but cheaper than buying a full set of new wheels!
2005 Cooper Chilli-SS+ HK-Chrono-Chrome Int/Ext-JCW Sound Kit
Redwytch's Raving's Redwytch's Website Was It You?
Old Mar 27th, 2006, 06:28 PM
MINICooperMurph's Avatar
aka Nick
Send a message via AIM to MINICooperMurph Send a message via MSN to MINICooperMurph
Take the wheel of the car and give it a really good scrub. This is much easier once the wheel is off the car. I would try some AG tar spot remover and see if that works. I have ismilar spots and am going to give that a go when its drier.
Old Mar 27th, 2006, 06:46 PM
jon vital's Avatar
I use wonder wheels. I've heard about the supposed harshness of it but haven't seen the proof of that claim.
Old Mar 27th, 2006, 07:04 PM
dietcokeplease's Avatar
Official MINI2 Fluffer
England Male
I use Wonder Wheels too. You just have to be careful to keep the solution applied to the wheel wet and not to let it dry out. The little ingrained speckles are brake dust that has pitted and dissolved into the wheel. I find that one of those bug sponges with webbing over it is the best solution and a hell of a lot of elbow grease. Don't rub too hard. Oh and using my fingernails to gentle remove them works too. Best thing to prevent future occurence is regular wheel cleaning and a coating of wax on the wheels.
There is just one moon and one golden sun; And a smile mean friendship to ev'ryone; Through the mountains divide, and the oceans are wide; It's a small world after all.
Old Mar 27th, 2006, 07:55 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Don't bother with the off the shelf products. They're all pretty much the same.
You need some Meguiars Wheel Brightener. It's what the professionals use. You mix it 4:1 with water to start with. If it's really stubborn brake dust mix it a bit stronger.
Your wheels will be fantastically clean again.
It was acceptable in the 80's
Old Mar 27th, 2006, 07:57 PM
Wonder wheels, used it loads of times, brilliant!!!
Old Mar 28th, 2006, 04:15 PM
notts04chillimini's Avatar
hey lightbulb head....
Send a message via MSN to notts04chillimini
England View notts04chillimini's Chili Red & White 1st Gen MINI Cooper Profile
wonder wheels to remove most of it then t cut and a bit of elbow grease to completly remove it....
then kae sure u give them a good coat of wax afterwards which will prevent such build up in future
Old Mar 28th, 2006, 04:36 PM
Mike Edwards's Avatar
England View Mike Edwards's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile View Mike Edwards's Classified Ads
Mini does a similar product that works well.
The other thing to try is the cleaning pads for use on plastic baths.
removing smoke stains from headliner Aurel Maintenance & MINI Care 2 Sep 1st, 2007 07:30 AM
Tip for removing Bird Cr*p Stains! Hyperspace Maintenance & MINI Care 0 Jul 17th, 2005 07:30 PM
Removing Water (not wax) Stains From Black Trim? sequence Maintenance & MINI Care 2 Jun 15th, 2005 02:24 PM
REMOVING white WAX stains from plastic Mini4000 Maintenance & MINI Care 8 Nov 30th, 2004 01:33 PM
