Old Apr 12th, 2006, 11:48 PM   #1
jimmy_racoon
Minnesota MINI
jimmy_racoon's Avatar
Local Time: 04:56 AM
Red Cooper Ladies & Gentlemen: Pull you rear wheels-now
I like my MINI clean and polished like the next guy. It may be a bit over the top to clean the inside of the wheels, but I do it. (Especially true if you got white wheels!)
Anyway, it had been a few months since I pulled the wheels and I almost couldn't get the rear wheels off! They were almost cemented to the axel at the wheel center. I saw a few posts that suggested giving it a few swift kicks. (Not the smartest thing to do when your MINI's up on a jack, but it did work, eventually.
Just thought I'd warn others to check this on their MINI. Hate to think what it would be like if I went more than a couple months. Or if I actually got a flat tire (no run-flats for this kid)
Anyway, was wondering if we need to apply a little axel grease to the inside center cap of the wheels to keep this from happening. Any input, mates? thanks
Motor on.
United States View jimmy_racoon's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Apr 12th, 2006, 11:56 PM   #2 (permalink)
Sarouk
I'll try again
Sarouk's Avatar
Local Time: 11:56 AM
I had the same problem in october when I decided to fit my set of winter wheels on. I unscrewed the bolts and... no way those alloy wheels would come off. I had to go to the garage where not less than two men finally managed to get them off. I fitted the winter set with grease on the axel, there was no problem. Changing wheels on friday i'll let you know if it helped.
Switzerland Male View Sarouk's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 13th, 2006, 12:05 AM   #3 (permalink)
jimmy_racoon
Minnesota MINI
Red Cooper Good, then I'm not necessarily crazy!
Thanks, Sarouk.
Glad to hear the axel grease may have helped.
I wonder if it's a winter thing.
We may have similar driving conditions in Minnesota, USA as you do in Switzerland.
I guess I'm lucky I got them off.
Quite a surprise at first!
thanks again
Motor on.
Old Apr 13th, 2006, 12:13 AM   #4 (permalink)
il-mostro
il-mostro's Avatar
Local Time: 10:56 AM
Send a message via AIM to il-mostro Send a message via MSN to il-mostro
Whenever i do any wheel off work, i always grease the hub where the two surfaces meet when i put the wheels back on. It always works for me.
ta ta, Mark.
Monster Monster
Old Apr 13th, 2006, 07:31 AM   #5 (permalink)
phil_wkl
phil_wkl's Avatar
I use copper grease, same stuff you put on the back of brake pads.
England Male View phil_wkl's Cool Blue & Black 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old Apr 13th, 2006, 01:52 PM   #6 (permalink)
petecrosby
Motorer extraordinaire
petecrosby's Avatar
Local Time: 05:56 AM
What you want to use is anti-seize, sparingly.
United States View petecrosby's Liquid Yellow & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 13th, 2006, 02:01 PM   #7 (permalink)
Richard22b
Yellow Mini Man
Richard22b's Avatar
Send a message via MSN to Richard22b
Talking
I had the same prob on every wheel.
Had to pay BMW to take them off for me.
All it took was a Karate style back kick and they were off. well maybe a couple of kicks.
Old Apr 13th, 2006, 02:35 PM   #8 (permalink)
a-z
a-z's Avatar
Local Time: 09:56 AM
Yup, copper grease on the back of the wheel hub and on the wheel nuts.
Something like this (I do note that you are in the USA)
http://www.motormania.co.uk/product_...turer=&Co de=
http://www.screwfix.com/app/sfd/cat/...p=tx3&id=79048
United Kingdom Male View a-z's Solid Black & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Apr 13th, 2006, 10:14 PM   #9 (permalink)
SteveM3
SteveM3's Avatar
Marvellous stuff .
England Male View SteveM3's Electric Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 14th, 2006, 04:44 PM   #10 (permalink)
Sarouk
I'll try again
Sarouk's Avatar
Well I changed my wheels today and only 1 gave me trouble ( the grease i put on did help ). Even strong kicks in it didn't do the job so I finally put the car back on the ground with the bolts slitly holding everything... Went back and forward a few times with strong bracking ( only a few meters) It helped to get it off.
Old Apr 15th, 2006, 03:16 AM   #11 (permalink)
jimmy_racoon
Minnesota MINI
Red Cooper bizarre
That is amazing...wonder why wheels want to stick like that.
Hope other motorers take notice and help figure this out.
thanks for the update, Sarouk
Old Apr 15th, 2006, 11:05 AM   #12 (permalink)
dietcokeplease
Official MINI2 Fluffer
dietcokeplease's Avatar
My dad had a problem with his wheels on his A-Class Merc. Typically it was a puncture on a rainy night that led to the discovery that the wheel was fused to the hub. No amount of kicking or dropping the jack would remove the wheel. In the end we had to call out the AA. The solution? A wooden block and a rubber mallet. Now I've coppegreased all the hubs on all our cars and my dads Mercs now carry blocks of wood and cheap rubber mallets.
There is just one moon and one golden sun; And a smile mean friendship to ev'ryone; Through the mountains divide, and the oceans are wide; It's a small world after all.
Old Apr 15th, 2006, 01:47 PM   #13 (permalink)
petecrosby
petecrosby's Avatar
It's electrolysis, set up by the contact of disimilar metals. The anti-seize grease forms
a barrier, lubricates the joint, and impedes rust.
Old Apr 16th, 2006, 04:07 AM   #14 (permalink)
jimmy_racoon
Minnesota MINI
Red Cooper you never know what you might learn...
thanks, pete
Just got some anti seize and will be applying tomorrow after a wheel detailing. Good that you took the time to explain why this occurs. Appreciate the input.
Here's to no more stuck wheels!
Motor on.
Old May 2nd, 2006, 06:34 AM   #15 (permalink)
endofnight
HrtofAg
endofnight's Avatar
Local Time: 03:56 AM
Send a message via Yahoo to endofnight
United-States
In many situations, the wheel staying on is a good thing!
That said, I'll be using grease the next time. Still, it won't be anything other than what is on hand . . . probably lithium based grease for bicycle wheels . . . but that should work.
It is important to note, perhaps, for readers not reading carefully, that we are talking about the wheel on the hub and not the lug nuts. I think I can say without fear of contradiction that you should never grease your lug nuts. I did once, on a VW. It had those great halfmoon hubcaps which caught the bolts and rang out a warning. Three bolts will hold a tire on for at least a little while.
United States Male View endofnight's Hyper Blue & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Ladies And Gentlemen,it's MAMA's Papa's jcsinnh New York & New England Region 3 Mar 16th, 2004 08:46 AM
Ladies en gentlemen: I am the owner of.... mhoutman MINI Cooper S 35 Jul 2nd, 2003 11:18 AM
