| They are tar spots, but tar spots don't have to be tar really. Can be bit's of melted tyre, hot flecks of brake dust. Best thing to do is try a clay bar system first. Meg's Quick Clay is ideal as a first clay system (available from Halfrauds). Wash your car thoroughly first, then use the clay with the lube provided. You might as well use it over the whole car while your at it to get the paint back as smooth as glass. You'll be shocked at the amount of dirt attached to your paint even after washing. Guide to clay: Snip clay into thirds to use. Use one side and once dirty fold over to create two clean sides (DO NOT turn it over as you will have no clean side fold over). Regularly check the clay and pick out any bits of grit that get onto it. If you drop it, discard it. ![]() It was acceptable in the 80's |
| Thanks My car's only 2 months old - is it still worthwhile using clay bar? As I noticed these things only after the first wash (when only a few days old) is it something to do every time I wash or use the tar remover in between? |
| As regards whether its okay to use the clay bar with your car being new, it will make a difference.Even from new my paintwork never really felt smooth and glassy like it should ,it always felt a little rough.I used a clay bar and could not believe the difference.Even if your not trying to shift tar spots i'd get a clay bar anyway. ![]() |
| Yeah, the car's are usually covered in a fair layer of grime by the time you pick them up so claying is good, even the day you pick the car up. A tar remover can be used also but it is a bit harsher than using a clay bar IMO. Basically try whatever you are comfortable using and get's the best results for you. ![]() It was acceptable in the 80's |
| tar remover is ok for small individual bits of contamination but it also strips off the wax so if you have to do large areas you end up having to re-wax as well. the clay bar is much better if the problem is wide-spread along the car. it also depends on whether you have polished/waxed over the tar spots previously - if you have you will need the tar remover to get through the wax to the contamination. the clay bar will only remove what's on the top surface. its a problem on all cars but it obviously looks worse on lighter colours. on the plus side at least we can see it & do something about it - owners of dark cars have a much harder job spotting & removing tar |
| Using Clay Bar ? | rec | Maintenance & MINI Care | 18 | Sep 24th, 2007 08:57 AM |
| clay bar | Wooly | Maintenance & MINI Care | 24 | May 15th, 2007 10:06 PM |
| Clay Bar | SteveBrass | Maintenance & MINI Care | 5 | May 23rd, 2005 12:34 PM |
| Clay Bar Use | Grumbler | Maintenance & MINI Care | 22 | Apr 30th, 2004 04:07 AM |
| Tar & Spot Remover............?? | AidenL | Maintenance & MINI Care | 8 | Apr 18th, 2003 04:13 PM |
