Visit Mini Mania UK
Old May 4th, 2006, 04:50 PM   #1
DSapseid
Now with added spotlights
DSapseid's Avatar
Local Time: 04:39 AM
Send a message via MSN to DSapseid Send a message via Skype™ to DSapseid
Pressure wash under bonnet???
Ive just open my bonnet to upgrade the headlight bulbs and noticed that the 'big sqaure thing' (really technical i know ) right at the front of the engine is coverd in all sorts of crap is ok to use the pressure wash on it or a can of compressed air or just a sponge and water or leave it well alone.
Dan
England Male View DSapseid's Pure Silver & Body Color 1st Gen MINI One Profile   Reply With Quote
Old May 4th, 2006, 05:08 PM   #2 (permalink)
minisoopercooper
Some have THICK skins!!!!
minisoopercooper's Avatar
Send a message via MSN to minisoopercooper Send a message via Skype™ to minisoopercooper
you can jet wash in the engine bay - I did but ended up loosing some of the bar code stickers on the cowel - other than that it was fine.
try with a spounge 1st and then if you have no luck try the jet wash.
Paul
↑↑↑ - Click me for the event of the year. - ↑↑↑
United Kingdom Visit my Blog at the Motorcade Male View minisoopercooper's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old May 4th, 2006, 05:14 PM   #3 (permalink)
memphisto
memphisto's Avatar
This is what the AA in Ireland had to say on the subject:
The AA is warning motorists not to pressure wash their way to a breakdown when cleaning the car. The widely used high-pressure washers, available at DIY stores for domestic use, can cause serious damage to cars if not used properly.
"You should never take a power hose to your engine, but some people do.” Says Emma Caulfield, Controller AA Roadwatch. "A bit of grime on the engine does the car no harm. The electrical connectors under the bonnet are highly protected by the manufacturer, but they are not designed to withstand being blasted by high pressure washers."
Typical faults which can develop can range from the car simply not starting after having been washed, to warning lights appearing on the dashboard, windscreen wipers operating when not expected to, or the car's lights not coming on at all.
The danger of using high pressure washers to wash the car does not stop at using them to clean the engine, they can also cause problems when cleaning the outside of the car. The high pressure can force water through seals into the boot or interior. Water can find its way into CD multi-changers and may damage them.
Today's cars are much more complex than 20 years ago when they simply had one computer to run them. Modern cars tend to have 40 or more computers, meaning that there are more possibilities for complex problems. High pressure power washers can force water into fuse boxes, relay boxes and connectors which can be found all over modern cars, and can cost hundreds of euros to repair.
My friend had to call out the RAC after he pressure washed his 02 Renault Espace engine, thankfully all was OK after it had dried out.
Old May 4th, 2006, 06:38 PM   #4 (permalink)
shiredweller
shiredweller's Avatar
Local Time: 10:39 PM
Agree with AA in Ireland.
.........but I could be wrong.
United States View shiredweller's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old May 4th, 2006, 06:41 PM   #5 (permalink)
Rakey
Four Candles?
Rakey's Avatar
tyre cleaner does a good job removing stubben marks and oil from the engine block, but do stay away from electrics
Old May 4th, 2006, 08:10 PM   #6 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
Get a good engine degreaser. Cover any open air filter and any electrical bits with tin foil.
Cover with degreaser and leave a few minutes. Rinse off with a stream of water (not pressured water). A watering can would be even better than a hose.
For any tough bits of grime; use the degreaser again and agitate with a brush.
It was acceptable in the 80's
Old May 5th, 2006, 03:30 PM   #7 (permalink)
minisoopercooper
obviously common sense prevails here and I didnt blast the electrics and avioded them
pressure wash???? my_mini 2nd Gen Exterior 64 Feb 15th, 2008 12:22 PM
Wash MINI by hand? or at wash? zhigadum Maintenance & MINI Care 3 Aug 13th, 2005 06:10 AM
Can you wash too much? thebluecanary Maintenance & MINI Care 12 Jul 16th, 2005 06:25 PM
