Cleaning the Engine bay - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 26th, 2006, 05:29 PM
Local Time: 08:09 AM
Hong Kong
Hong Kong Cleaning the Engine bay
Hi,
What is the best method to clean the engine bay? Please advise.
Lemoncoke
Milltek Cat-back..
KW V2
ES 100
Old Jul 26th, 2006, 05:33 PM
OctaneGuy's Avatar
MINI2 Sr.
Send a message via Skype™ to OctaneGuy
Local Time: 05:09 PM
United States Male
I use a good car wash soap, and a body brush, the kind sold to wash your paint, and several sizes of nylon brushes, like the kind used for the wheels.
I cover the alternator and ECU and use a gentle flow of water. I prefer to use a bug sprayer type where you fill container with water, pump several times, then you can use wand to expel water. 1/2 gallon is all you need to rinse and wash engine bay.
I also use Meguiar's APC (All Purpose Cleaner) or Safe D-Greaser to remove oily residue.
Watch the first video on this link to learn more about how to wash your MINI.
http://www.showcargarage.com/
Richard
Quote: Originally Posted by lemoncoke
Hi,
Lemoncoke
Polishing paint is not just my profession, it's my obsession.
Old Aug 4th, 2006, 06:04 PM
Chilli
Local Time: 12:09 AM
i take thats your MINI in the video? very nice! great video btw , got some great tips from it!
Old Aug 4th, 2006, 08:08 PM
OctaneGuy's Avatar
MINI2 Sr.
United States Male
Thank you! Yes, that's my MINI. I just bought new wheels, so it looks a little different now with black wheels with polished lip. =)
I took the above photo before I made these MINI covers
Richard
Old Aug 5th, 2006, 04:39 PM
Local Time: 01:09 AM
England
Engine Compartment Detailing
Hi,
Lemoncoke
Cleaning Methodology:
· I would recommend wearing a pair of Nitrile powder free Micro Textured gloves when cleaning
grease and grime, always protect your hands while working on the engine compartment. Road
grime, tar and grease are very difficult to remove from underneath your fingernails, outside of the
garage your hands shouldn't look like you need lessons in personal grooming
· Remove any excess debris, leaves and etc from the hood, grille or air-vent openings
· Spray electrical connectors with WD40 which repels moisture / water (avoid spraying on belts)
· Use cling-film or Saran wrap elastic covers to cover any sensors, electrical black boxes, electrical devises that could cause an electrical short-circuits if subjected to water spray.
· This will not guarantee that you won’t cause a problem when cleaning an engine bay but it will greatly reduce the risks.
· Start and run the engine to get it warm, not hot, this will enable the de-greaser to work more efficiently on a warm surface.
· Apply an engine de-greaser (Autoglym Engine Cleaner) or a citrus-based general cleaner (P12S Total Auto Wash) by lightly spraying the lower parts of the engine first and then working upwards.
· Enable the cleaner to work by allowing dwell time (but do not allow to completely dry)
· Do not allow the de-greaser to dry or remain on painted surfaces, and be sure to dilute with water before drying with a cloth.
· For heavily soiled areas agitate with a nylon engine cleaning brush and a diluted citrus-based cleaner (P21S® Total Auto Wash)
· When the grease and grime is dissolved and you're ready to remove it, spray with a light (garden type) pressure water hose.
· Use the blower side of a vacuum (avoid area that may be sensitive to a forced air flow) or allow the engine compartment to air dry and then thoroughly wipe down all accessible surfaces and then remove cling-film or aluminium foil.
· When everything is dry apply a vinyl/rubber protectant
to hoses, shields and wires, and wipe engine parts with
CD2 Engine Detailer
· Wipe off any excess with a clean cloth and apply a wax/sealant protection to painted surfaces.
Note- Apply a vinyl dressing to hoses etc (no diethyl silicone fluid based dressings (DS) should be applied in the engine compartment. Use only water based polydimethalsiloxane (PDS) dressings and do not directly spray on to engine parts, spray a cloth and wipe
Old Aug 5th, 2006, 06:30 PM
SiBradbury's Avatar
United Kingdom Male View SiBradbury's Classified Ads
Tin foil is sometimes a good alternative to clingfilm as it is easier to shape around stuff!
Old Aug 6th, 2006, 04:18 PM
PrplPplEtr's Avatar
Countdown to Ecstacy
Local Time: 08:09 PM
United States View PrplPplEtr's Black-Eye Purple & Body Color 1st Gen MINI Cooper S Profile
togwt, i'd like to read your post, but the blue type on the black page just makes it a headache to read. i'm sure you have good things to say, why hide them with the difficult color?
06 MCS JCW PH/PH premium, sport, webspokes, black leather, anthracite dash and headliner.
Old Aug 6th, 2006, 04:25 PM
England
·I would recommend wearing a pair of Nitrile powder free Micro Textured gloves when cleaning
·Remove any excess debris, leaves and etc from the hood, grille or air-vent openings
·Spray electrical connectors with WD40 which repels moisture / water (avoid spraying on belts)
·Use cling-film or Saran wrap elastic covers to cover any sensors, electrical black boxes, electrical devises that could cause an electrical short-circuits if subjected to water spray.
·This will not guarantee that you won’t cause a problem when cleaning an engine bay but it will greatly reduce the risks.
·Start and run the engine to get it warm, not hot, this will enable the de-greaser to work more efficiently on a warm surface.
·Apply an engine de-greaser (Autoglym Engine Cleaner) or a citrus-based general cleaner (P12S Total Auto Wash) by lightly spraying the lower parts of the engine first and then working upwards.
·Enable the cleaner to work by allowing dwell time (but do not allow to completely dry)
·Do not allow the de-greaser to dry or remain on painted surfaces, and be sure to dilute with water before drying with a cloth.
·For heavily soiled areas agitate with a nylon engine cleaning brush and a diluted citrus-based cleaner (P21S® Total Auto Wash)
·When the grease and grime is dissolved and you're ready to remove it, spray with a light (garden type) pressure water hose.
·Use the blower side of a vacuum (avoid area that may be sensitive to a forced air flow) or allow the engine compartment to air dry and then thoroughly wipe down all accessible surfaces and then remove cling-film or aluminium foil.
·When everything is dry apply a vinyl/rubber protectant
CD2 Engine Detailer
·Wipe off any excess with a clean cloth and apply a wax/sealant protection to painted surfaces.
This is black type
Old Aug 7th, 2006, 12:13 PM
NickG's Avatar
Send a message via MSN to NickG
United Kingdom Male View NickG's Dark Silver & Black 1st Gen MINI Cooper S Profile
Maybe you should read up on website accessibility, and be more considerate of MINI2 members who may not have perfect vision rather than mocking them.
Old Aug 7th, 2006, 07:52 PM
SiBradbury's Avatar
Is there REALLY an arguement brewing over text colour?
Let's all get back to the point of this thread....
Thanks for the post TOGWT despite being like one of those 'magic eye' pics it was very helpful ( i guess it depends which Mini2 Skin you're using deems if it's hard to read or not, i guess you probably cut and pasted it in that colour)
Old Aug 8th, 2006, 10:24 AM
NickG's Avatar
Apologies I forgot about the different MINI2 styles, I thought the TOGWT was being deliberately unhelpful.
TOGWT, you need to post that text into notepad first then copy it into MINI2 that way it will work well with both styles.
"Is there REALLY an argument brewing over text colour?"
If it hadn't been a misunderstanding then I think that deliberately presenting information that is potentially unusable to a significant portion of the population is well worth arguing over.
Old Aug 8th, 2006, 05:43 PM
SiBradbury's Avatar
If it wasn't a misunderstanding then he'd surely be doing it on purpose and nobody is that mean!
"Hey everyone, here's loads of useful info for you all! Except you lot with bad eyesite! You deserve a dirty engine bay"
hahahaha!
Old Aug 14th, 2006, 08:57 PM
England
The information is indeed a ‘cut and paste’ from a book (of which I am the © author) with no intent to be unhelpful to those with failing eyesight (which at 60+ includes me) anyone who knows TOGWT will tell you that I post to most of the popular forums with the intent of sharing the knowledge obtained over fifty years of detailing [knowledge unshared is experience wasted] as for being mean I’m far to busy / too old to waste my time.
As you can see I’ve tried ‘blue’ and ‘black’ type so how do I ‘type in a colour that will show up clearly on MINI2’s background?
Old Aug 15th, 2006, 10:48 AM
Perm's Avatar
Just type in white like everyone else....
Perm
  #15 (permalink)
Old Aug 15th, 2006, 09:47 PM
England
Perm
Engine and Bay Cleaning Mins21 First Generation MINI Tuning 0 Jun 18th, 2007 03:09 PM
Engine bay cleaning doombuggy Maintenance & MINI Care 0 Jul 1st, 2005 04:07 PM
Clonking from engine bay russs99 General Discussion 3 May 28th, 2005 06:01 PM
Engine Cleaning Jacko Maintenance & MINI Care 22 Feb 22nd, 2005 10:03 PM
Cleaning inside the engine bay AussieMini Maintenance & MINI Care 10 Dec 13th, 2002 09:24 PM
