| How about a stiff toothbrush and some warm/hot water? If the bugs are hard and crusty you might want to stop by your local hardware store and pick up a coarse wire brush. 2002 Dark Silver Cooper S w/ white roof. SOLD |
| that's the quickest way to ruin your rad I'd say, the rad I suppose can be cleaned with a jet of water from a hose, but I'd leave it well alone, The supercharger's part can be wiped over gently with a damp cloth, but I wouldn't put to much pressure on it, for fear of damage! |
| My experience on my Cooper S is to let the dead bug carcasses soak with water until they get all soft and mushy . Then a fairly gentle stream of water from a garden hose will flush them away. I found the regular radiator collects a lot of bugs, but the intercooler hardly gets any. Perhaps this is because at speed the airflow moves to bugs over the intercooler scoop? (and on up the the windshield from what I can figure! ) + 2002 MINI Cooper S - Dark Silver / White roof, Sport, Premium, Lapis blue leather + 1965 Mini Traveller - Tartan Red / White roof, 1275, Cooper S discs, fully restored/renewed |
| Or you could try this stuff. I've seen similar products at my local car part store. I can't say how well it work though... http://www.simplywow.com/store/catal...4de5b0c8bcd930 2002 Dark Silver Cooper S w/ white roof. SOLD |
| A hosepipe aimed at the Rad/Intercooler should be adequate to remove most of the critters. Be careful when using any brushes as the Rad fins are made from soft metal and are easy to damage/distort. If it really bugs you (boom boom ) then do what I do - use a cocktail stick to carefully dig out the bodies.BugFreeDC There is just one moon and one golden sun; And a smile mean friendship to ev'ryone; Through the mountains divide, and the oceans are wide; It's a small world after all. |
| BTW, since it has come up several times in this thread, for those of you that don't know: (UK)hosepipe = (US)garden hose + 2002 MINI Cooper S - Dark Silver / White roof, Sport, Premium, Lapis blue leather + 1965 Mini Traveller - Tartan Red / White roof, 1275, Cooper S discs, fully restored/renewed |
| For the intercooler, I simply removed the plastic cover over the fins, layed a cut section of typical window screen on top of the fins, and re-installed the cover. I use the nylon screen you can buy in any hardware store. Since it is fire retardant, it is immune from the hot surface of the intercooler. It works great and prevents the bugs from becoming wedged in the fins. You can remove any insects on the window screening with a vacuum cleaner with a brush attachment. For the radiators, you cannot block all the bugs, but you can get the big ones and any stones by using screening with relatively wide openings (don't what to block too much air). I used some stainless steel wire mesh (about 5mm holes with 12 guage wire) and fastened it behide the grille using thin zip-ties (the zip-ties are hidden behind the grille slats on top). black ties are hardly noticable on the black lower grille. Obsessive? yes, but we got lots o' bugs here in MO. |
| It really bugs me | Chokey | General Discussion | 7 | Jul 3rd, 2006 10:58 AM |
| MINI bugs....no really, BUGS | flav | General Discussion | 4 | May 25th, 2004 06:26 AM |
| bugs on the radiator | tomgates | Maintenance & MINI Care | 3 | Sep 22nd, 2003 11:25 PM |
| Rid your car of bugs for really cheap! | Branston | Maintenance & MINI Care | 13 | Aug 30th, 2003 10:32 AM |
| Bugs Stain | Jomnhta | Maintenance & MINI Care | 5 | Jul 11th, 2003 04:51 AM |
