Coolant - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 4th, 2006, 09:22 AM
Local Time: 01:10 AM
Apple Cooper Coolant
How often should you check the coolant level and how often should you expect to top it up?
Old Sep 4th, 2006, 09:24 AM
KPKalle's Avatar
50 PMs no sig group
Local Time: 12:10 AM
England Male View KPKalle's Laser Blue & White 2nd Gen MINI Cooper S Profile
Not very often, unless you've got a leak. I've only topped mine up once in a little more than two years.
Old Sep 4th, 2006, 09:30 AM
Thanks, actually the coolant reservoir is completely empty and someone reversed into the front of my car a few weeks ago. I'm wondering if the 2 could be related. There was only minor cosmetic damage to the paintwork, or so I thought.
It is so empty that there are flaky bits in the reservoir, but no warning lights came on. I've had my MC since 2002 and topped up the coolant myself just once.
The car has been working fine. I hope no serious mechanical damage has been inflicted.
What coolant should I use? fergusor First Generation MINI Tuning 3 Jun 11th, 2007 09:21 AM
Coolant? Ginger First Generation Faults & Fixes 17 Sep 13th, 2004 08:04 PM
Coolant ruthie Maintenance & MINI Care 2 Feb 26th, 2003 06:59 PM
More Coolant? xnetco Maintenance & MINI Care 6 Jan 30th, 2003 10:55 AM
