| Front Seat-Back Problem Help! The front passenger seat-back will not "unadjust" from the full tilt back position. Any tips? I pulled up on the inner seat adjust lever to tilt the seat-back up from the fully back (reclined) position, and the seat-back will not release. The lever to release the seat-back to let the rear passenger out releases the seat-back but the back will not latch in any position other than the fully reclined position You can call me Flower if you want to |
| I had this same problem on my '06 S. Basically what I did was to play with both levers, pulling them up and down and after a couple minutes it seemed to release whatever was jammed and haven't had a problem since. |
| The fix took about 30 seconds -- the service guy, facing Flower's rear, put his knees on the seat and with both hands gave a pretty good "whomp" (his term) in the middle of the seat-back top. This released whatever was keeping the seat-back in the fully reclined position. The service guy said if I do that do not do it too hard -- a broken seat back is not covered under the warranty You can call me Flower if you want to |
| car seat for back seat | moosie | MINIs, Children & Parents | 13 | Aug 20th, 2006 08:18 AM |
| Seat back come off!! | Jukesy | First Generation Faults & Fixes | 9 | Jul 8th, 2006 08:15 AM |
| Front Seat - problem with folding / slide forward | russ210171 | First Generation Faults & Fixes | 6 | Apr 12th, 2006 06:38 AM |
| driver seat back | viking1948 | First Generation Faults & Fixes | 1 | Mar 30th, 2005 05:33 PM |
| Scuffed at the back of the front seat | hburdin | First Generation Interior & Ice | 6 | Jan 20th, 2004 11:53 AM |
