| someone else will confirm, but i believe its the top of the hatchd part only, i topped mine up last week and have had no problems etc. although the handbook does not help with this as the dipstick it describes is nothing like mine as they say it has a max mark on it and a min, which i did not |
| urrr...actually the level should be checked when the engine is cold and not just aftr it has been used. If the engine has been left sitting then the levels are correct as most if not nearly all oil is in the resevior...if the engine has just been used its lying on all the surfaces so will read incorrrectly. should be between the hatchings on the yellow bit of dip stick. |
| The top of the hatch part!!!! not top of the yellow thingy! The hatch mark area represents 1 quart of oil (at least in the US). Bottom of hatch means you need 1 quart. Perhaps it is 1 liter for you. Your level was at the top of the yellow AFTER you drained some? You didn't describe your major problems but you're going to keep having them until you drain some more. |
| I'm sure my 52 handbook says to check cold?! Will look tonight. Basically all my previous cars and my haynes manual always said park the car up on the level and let the engine settle. Check the oil when cool so that the oil thats been whizzed round the engine is now in the bottom. The level should be within the crosshatched area of your dipstick. Over filling is not the end of the worrl as the car will cope...not the best plan but it'll be ok in the main. Best to drain some if you can. I would say that it should be at the top of the cross hatch when cold and nearerr the bottom of the cross hatch when warm. At no point should it be above or below the cross hatching. |
| Most manufacturers warn against overfilling. Indeed they prefer that the level is run below the upper mark on the dip stick. One reason for this is that, on engines with cambelts rather than a chain, the oil can get onto the cambelt and cause premature failure. Far better to run an engine with the oil around the mid point on the dip stick than keep trying to top up. On the R56 MINI have gone further and advised to only top up when a yellow light indicates it is necessary. |
| Topping up the oil level | crimond | Maintenance & MINI Care | 8 | May 29th, 2007 09:54 AM |
| Oil Level | thrud | Second Generation MINI Cooper S | 8 | Dec 18th, 2006 07:22 PM |
| oil level / transmission | neilo | First Generation MINI Cooper | 3 | Jan 17th, 2005 11:05 AM |
| Q: CVT Oil level... | tog255 | First Generation CVT & Automatic | 2 | Sep 10th, 2004 05:42 AM |
| Testing Oil Level | Tone | Maintenance & MINI Care | 10 | Sep 10th, 2003 10:08 PM |
